Lots of unkown
 1-2  …  163-182  183-202  203-222  223-242  243-262  …  363-372
8665.203
thanks !
- Tudor -
8665.204
rectangle round corner if forgot check button - applies instead of cancel entire op
- Tudor -
8665.205
for offset - here's a solution
if (pointpicker.event == 'finished') {
moi.command.setOption('OffsetCurveDistance', factory.getInput(1));
break;
if I'll need i can swap from thought point, to distance by hotkey or manual .. it will remember last input
offset factory input 1 = distance
but
moi.ui.alert(factory.getInput(1)) returns moi.object. Is a way to return value? or search for another way ?
- Tudor -
8665.206 In reply to 8665.205
Hi Tudor,
factory.getInput(index) returns a geometry factory input object which has a getValue() function on it.
8665.207
sry but I have and error ..
it's making smt & I can't define where's the error
- Tudor -
Size: 309.4 KB, Downloaded: 73 times, Dimensions: 1249x410px
8665.208 In reply to 8665.207
Hi Tudor, if the input has never been initialized with any value, it will throw an "operation failed" exception.
So you would need something like:
var gotvalue = false;
var value;
try {
value = input.getValue();
gotvalue = true;
} catch(e){}
8665.209
nope
factory.getInput(1) - returns object
factory.getInput(1).getValue() - always undefined
my assumption is that
1. cuz it wasnt any init from js (factory.setValue(1)...) it cant read the values from factory
2. factory.getInput(1) - has a different object format
3. curveOffsetDistance internal is returning undefined after execution -> while dragging offset - the value is always 0
I give up
- Tudor -
Size: 22.5 KB, Downloaded: 68 times, Dimensions: 520x339px
8665.210 In reply to 8665.209
Hi Tudor, if you can post a complete script file that I can run over here I can take a look.
8665.211
vanilla offset with hotkeys modifications
d -> swap from thought point to distance -> idea is to keep through point to distance value, so on next offset will remember last action -> since distance has already a build-in setOption
- Tudor -
8665.212 In reply to 8665.211
Hi Tudor, for offset the input index 1 is for a distance value, it is only filled in if you are using offset in its "offset by specific distance" mode, not in through point mode.
So for example if you type in 3 and push enter that input will get initialized to 3 and then your messages would show "3" and "true" when you pick a point for which side to offset on.
There was at one point a "curveOffsetDistance" additional property on the offset factory that would give back the current distance used for "through point" mode, but it's not working currently. I'll take a look and see if I can get that working.
8665.213
Isocurve
v - swap between u/v
b - both
- Tudor -
8665.214
Hi Michael
another future that i'd like to see -> u might not accept it
ctrl dragging(dublicate) - assign snap during dragging -> shift is straight, alt -> removes snaps, what about 'space' - readjust snapping point (readjust anchor position)
8665.215 In reply to 8665.214
Hi Tudor, sorry no I don't think that would be very easy to add. If you want a specific anchor position, use the Transform > Move command instead of object dragging.
8665.216
I'll put this at wish List
habit for select - apply action -> fillet/chamfer control points
the way it works now if points are selected, u can't apply action instead is returning to object selection
- Tudor -
8665.217
Chamfer hotkeys -> works only with 1 distance
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
8665.218
scale/rotate/move gizmo
move - holding shift has a snapping direction, will be nice also for scale snapping direction
- Tudor -
8665.219
found a solution for move -> copy
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
Move
added C -> move copy (duplicate origin with move hotkeys options), works before 1'st picked point
- Tudor -
8665.220 In reply to 8665.218
Hi Tudor,
Shift is already being use there for a different function, it does a 2D scale instead of a 3D scale.
8665.221
Hi again !
So a question about pointpicker -> Is any option to force update ?
I've noticed in move commands - where I swap axis by hotkeys & it won’t update until I'll do a mouse move - seems that forces to update factories
now I'm working in combining rectangles under 1 script - needs also a pointpicker update (I'm updating factory - but since pointpicker haven't changed -> no updates) have a basept, need to update second pt or waitable pointpicker pt
- Tudor -
8665.222 In reply to 8665.221
Hi Tudor,
Not currently but I have added in a pointpicker.recalc() function for the next beta to do that.
Show messages:  1-2  …  143-162  163-182  183-202  203-222  223-242  243-262  263-282  …  363-372
