Lots of unkown
 1-16  …  157-176  177-196  197-216  217-236  237-256  …  357-372
8665.197
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.136
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
//added
small adjustments
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
EDITED: 16 Aug 2020 by CEMORTAN_TUDOR
8665.198
Hi Michael
for offset - through point, I wanna store value for next op - have the same as previous - how shall I do it ? (temporary global save*)
- Tudor -
8665.199
magic of offset ~ weird behavior
- Tudor -
8665.200
I've tested in other software to see if it's rly a problem !
Rhino Fails - buggy
DesignSpark Mechanical - buggy
Illustrator - it doest care about continuity
Fusion 360 - it maxed the continuity- when it breaks, will round corners
- Tudor -
Size: 581.4 KB, Downloaded: 117 times, Dimensions: 1482x1524px
8665.201 In reply to 8665.198
Hi Tudor,
There's moi.command.setOption() and moi.command.getOption() that can be used for that.
The setOption works like: moi.command.setOption( 'string_id', val );
getOption goes like this:
var val = moi.command.getOption( 'string_id' );
One thing to watch out for is that getOption() will throw an exception if there isn't anything saved with that string id before, so you need to use it in a try/catch block like this:
var Val = 5;
try {
Val = moi.command.getOption( 'string_id' );
catch(e) {}
8665.202 In reply to 8665.199
Hi Tudor,
Offset has been tuned up quite a bit already for the next beta and it shouldn't make the weird excessive extensions anymore.
It will try to make a G2 continuous extension but it looks at how much the extension bends and once it is beyond a limit it switches to G1 line extensions:
8665.203
thanks !
- Tudor -
8665.204
rectangle round corner if forgot check button - applies instead of cancel entire op
- Tudor -
8665.205
for offset - here's a solution
if (pointpicker.event == 'finished') {
moi.command.setOption('OffsetCurveDistance', factory.getInput(1));
break;
if I'll need i can swap from thought point, to distance by hotkey or manual .. it will remember last input
offset factory input 1 = distance
but
moi.ui.alert(factory.getInput(1)) returns moi.object. Is a way to return value? or search for another way ?
- Tudor -
8665.206 In reply to 8665.205
Hi Tudor,
factory.getInput(index) returns a geometry factory input object which has a getValue() function on it.
8665.207
sry but I have and error ..
it's making smt & I can't define where's the error
- Tudor -
Size: 309.4 KB, Downloaded: 73 times, Dimensions: 1249x410px
8665.208 In reply to 8665.207
Hi Tudor, if the input has never been initialized with any value, it will throw an "operation failed" exception.
So you would need something like:
var gotvalue = false;
var value;
try {
value = input.getValue();
gotvalue = true;
} catch(e){}
8665.209
nope
factory.getInput(1) - returns object
factory.getInput(1).getValue() - always undefined
my assumption is that
1. cuz it wasnt any init from js (factory.setValue(1)...) it cant read the values from factory
2. factory.getInput(1) - has a different object format
3. curveOffsetDistance internal is returning undefined after execution -> while dragging offset - the value is always 0
I give up
- Tudor -
Size: 22.5 KB, Downloaded: 68 times, Dimensions: 520x339px
8665.210 In reply to 8665.209
Hi Tudor, if you can post a complete script file that I can run over here I can take a look.
8665.211
vanilla offset with hotkeys modifications
d -> swap from thought point to distance -> idea is to keep through point to distance value, so on next offset will remember last action -> since distance has already a build-in setOption
- Tudor -
8665.212 In reply to 8665.211
Hi Tudor, for offset the input index 1 is for a distance value, it is only filled in if you are using offset in its "offset by specific distance" mode, not in through point mode.
So for example if you type in 3 and push enter that input will get initialized to 3 and then your messages would show "3" and "true" when you pick a point for which side to offset on.
There was at one point a "curveOffsetDistance" additional property on the offset factory that would give back the current distance used for "through point" mode, but it's not working currently. I'll take a look and see if I can get that working.
8665.213
Isocurve
v - swap between u/v
b - both
- Tudor -
8665.214
Hi Michael
another future that i'd like to see -> u might not accept it
ctrl dragging(dublicate) - assign snap during dragging -> shift is straight, alt -> removes snaps, what about 'space' - readjust snapping point (readjust anchor position)
8665.215 In reply to 8665.214
Hi Tudor, sorry no I don't think that would be very easy to add. If you want a specific anchor position, use the Transform > Move command instead of object dragging.
8665.216
I'll put this at wish List
habit for select - apply action -> fillet/chamfer control points
the way it works now if points are selected, u can't apply action instead is returning to object selection
- Tudor -
Show messages:  1-16  …  137-156  157-176  177-196  197-216  217-236  237-256  257-276  …  357-372
