Lots of unkown
 1  …  142-161  162-181  182-201  202-221  222-241  …  362-372
8665.182
move - expanded first actions - move + x/y/z/a initial conditions (earlier script respond after first pickedpoint)
s - bbox center
extrude - do backup as part is havelly changed from vanilla
p path
b both directions
c cap ends
d directional // changed - removed distance line and input distance (slightly buggy on surfaces if keypressed while moving mouse - I think it can't update in time and skips update factory)
f tapered/flip tapered
Numpad+ increase tapered angle by 15
Shift+Numpad+ increase tapered angle by 5
Numpad- decrease tapered angle by 15
Shift+Numpad- decrease tapered angle by 5
removed t as hotkey
boolean difference
for closed curves
initial and subtractive if both are on same parallel frame but different frame
move subtractive group to initial and do the boolean difference (made for side views where u see that u have 2 circle's but u cannot subtract cuz they have different frames)
- Tudor -
8665.183
crv.evaluateCurvature - how can I access first and second pt of vector ? -> tried -> [], item(), getStartPt()
- Tudor -
8665.184 In reply to 8665.183
Hi Tudor,
There is not a first and second point returned, it returns one vector value (with .x, .y, .z - same as a point) for the curvature vector (K) of the curve in the osculating plane at that parameter value. Radius of curvature = 1 / Magnitude K.
https://en.wikipedia.org/wiki/Curvature#Osculating_circle
8665.185 In reply to 8665.183
re: crv.evaluateCurvature, here is some test code. Make a curve, select it and then push the Tab key and paste this in to the XYZ input control:
var crv = moi.geometryDatabase.getSelectedObjects().getCurves().item(0);
var pt = crv.evaluatePoint( crv.domainMin );
var K = crv.evaluateCurvature( crv.domainMin );
var f = moi.command.createFactory( 'line' );
f.setInput( 0, pt );
f.setInput( 1, moi.vectorMath.add( pt, K ) );
f.commit();
That will make a line showing the curvature vector. The radius of curvature is 1 / length of that line.
Curvature vectors are generally scaled up by quite a bit when used for visualization purposes. They tend to be small in their direct form.
8665.186
thanks ! that's what i've needed !
- Tudor -
8665.187
how can I get toplevel from a selection (ex:face or edge to object)
- Tudor -
8665.188 In reply to 8665.187
Hi Tudor,
var toplevel = subobj.getTopLevelParent();
8665.189
Hi Michael !
is it possible to attach moi-html to chrome to have futures like object explorer/building html ?
or other ways to debug
EDITED: 23 Jul 2020 by CEMORTAN_TUDOR
8665.190 In reply to 8665.189
Hi Tudor,
> Hi Michael !
No, not currently. In the future I want to have a script debugger in MoI, it will involve a lot of work to make that happen though.
Message 8665.191 deleted 27 Jul 2020 by CEMORTAN_TUDOR
8665.192
Hi Michael !
I think this should rise an error
createPoint(moi.vectorMath.add(obj.getStartPt(), scaleVector(obj.evaluateTangent(obj.domainMin), -1))).commit() - correct state
createPoint(moi.vectorMath.add(obj.getStartPt(), scaleVector(obj.evaluateTangent(obj.domainMin)),-1)).commit() - should rise -> it creates an null point
function scaleVector(v, factor) ... return moi.vectorMath.createPoint(x,y,z)
- Tudor -
8665.193
Hi Michael !
I'm working a script & I wanna optimize it ! it uses a lot of moi.vectorMath.add()
wanna ask what's the math behind that function ? mb will improve runtime (not to call internals todo math operations )
- Tudor -
8665.194 In reply to 8665.193
Hi Tudor,
Like this:
var PtA, PtB, Result;
Result.x = PtA.x + PtB.x;
Result.y = PtA.y + PtB.y;
Result.z = PtA.z + PtB.z;
8665.195
scripts for edge selection :
I wanted ~ growLoop similar to Subd, with v4 it became possible
works only for 1 selected object -> possible multiple edge selection
_GrowSelectionTangecy - expands only once
_ExpandSelectionTangecy - expands full selection
testing files are on moi_objects.rar
I haven't done more optimization since ~ 140ms is good result on big_object test (started from 20s -> 2s -> 1.2s-> 0.140)
quick Notes:
factory.Update() + getCreatedObjects() - it's slow process - better avoid it
looping same object - debugging -> might have different selection order - idk why it's happening - have to place into java object
Ps: why getEndPt() != domainMax ?
EDITED: 10 Aug 2020 by CEMORTAN_TUDOR
8665.196
add point
D -> delete corners
- Tudor -
8665.197
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.136
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*2
Numpad/ -> value/2
//added
small adjustments
Ctrl+Shift+Numpad+ -> value +value/100
Ctrl+Shift+Numpad- -> value - value/100
r - reset distance to 0 -> to start new one
EDITED: 16 Aug 2020 by CEMORTAN_TUDOR
8665.198
Hi Michael
for offset - through point, I wanna store value for next op - have the same as previous - how shall I do it ? (temporary global save*)
- Tudor -
8665.199
magic of offset ~ weird behavior
- Tudor -
8665.200
I've tested in other software to see if it's rly a problem !
Rhino Fails - buggy
DesignSpark Mechanical - buggy
Illustrator - it doest care about continuity
Fusion 360 - it maxed the continuity- when it breaks, will round corners
- Tudor -
Size: 581.4 KB, Downloaded: 117 times, Dimensions: 1482x1524px
8665.201 In reply to 8665.198
Hi Tudor,
There's moi.command.setOption() and moi.command.getOption() that can be used for that.
The setOption works like: moi.command.setOption( 'string_id', val );
getOption goes like this:
var val = moi.command.getOption( 'string_id' );
One thing to watch out for is that getOption() will throw an exception if there isn't anything saved with that string id before, so you need to use it in a try/catch block like this:
var Val = 5;
try {
Val = moi.command.getOption( 'string_id' );
catch(e) {}
Show messages:  1  …  122-141  142-161  162-181  182-201  202-221  222-241  242-261  …  362-372
