Lots of unkown
 1-4  …  105-124  125-144  145-164  165-184  185-204  …  365-372
8665.145
dont have them xD well, it was a suggestion(intuitively will be right and left - ! all we know what it means xD no x & y's - it was written right side ! why it haves weird xD ))
I'm in another propose script ~ isolate update
now - the way it works it now it isolates objects, next call unhides all
what i want - isolate to update on selected objects(ex: doing some operation on objects, isolate to work further), on deselect - call isolate - unhide all. for that i need a global variable ! as I've read scripts all variables are inside scripts (i'm still learning js)
benefits - hitting twice isolate to work further - not to much ~ clicking saving
EDITED: 4 Jul 2020 by CEMORTAN_TUDOR
8665.146
options vanilla - save current color style as default
I respect blender for community they've grow
Size: 199.9 KB, Downloaded: 127 times, Dimensions: 676x575px
8665.147
cplane as internal doesn't have options locating hotkeys reset, etc
I like pointpicker.addSnapPoint( startpt, moi.ui.getText('Closed snap') ); -> moi.ui.getText()
can it be fixed at a viewport camera position (aka : bottom right; wanna do mini helper for added hotkeys that i'm doing ~ https://youtu.be/8k2NGWrKbj4?t=1239 bottom right ) only when moved over show helper (new lines will be welcome) : personalized -> mb yes -> if u won't see growth in this direction ! (I know that u want viewport as clean as possible, asking for ~ a helper point/style without can be improved - need agreement )
this also can be applied to filters ( which I have to have opened browser to view which one is active - aka edg/faces/solids/so on)
- Tudor -
8665.148 In reply to 8665.145
Hi Tudor,
No, that's not how it works now. The way it works now is on the first call it saves a snapshot of the hide/show state of all objects to internal memory, then it does an isolate. The next time you trigger it, it restores things to the pre-isolate snapshot.
For example starting with 6 objects, these 4 are hidden:
Select this object:
Do Isolate, now it is the only one visible and the other 5 are hidden:
Do Isolate a second time, only the object that was visible when the first Isolate was done is visible, not the other 4 objects which remain hidden:
8665.149 In reply to 8665.146
Hi Tudor,
You can do that in MoI by saving a .3dm file with the colors set how you want, then set it as the startup template file under Options > General > Template file, the styles in that file will be used as your default ones when you start up MoI or when you do a File > New :
8665.150 In reply to 8665.147
Hi Tudor:
You can set up a shortcut key for cplane reset by putting in this on a shortcut key:
script: moi.view.resetCPlane();
Also a right-click on the View > CPlane button is a shortcut for reset.
There isn't any mechanism for displaying viewport text at a fixed screen location, I would recommend using a dialog for something that stays fixed on screen rather than a viewport display object.
8665.151 In reply to 8665.147
Hi Tudor,
It would be a good idea to have an additional indicator for a filter being active up here somewhere, I've added that to my list of things to look into after v4 is finished.
8665.152
1. About isolate - it's not my idea !
It comes from softimage - it has several layers of hidden properties
1. render - can overrides lower layers
2. groups - individual only manual changed - overrides lower layers
3. layers ~ similar to objects name in moi
2. individuals ~ moi - selected object hide
1. isolate - lowest level (can tunnel from isolate to isolate until 1 object will remain - nothing else then exit)
2. Ini - thanks
3. Cplane - my idea is to combine hotkeys under groups, later expand them (c only for cplane, hotkeys after part of cplane grouping - aka reset)
~ on rest of scripts there's a waitable object where it can be placed, here i can't setup under a group
- Tudor -
8665.153 In reply to 8665.152
Hi Tudor,
Sounds very complicated.
Yes, the cplane's event loop happens to be implemented with C++ code inside moi_lib.dll instead of in
script code so there isn't any way you can alter that one. You would have to set up your own
script for it instead.
8665.154
now i'm more confused
expanding http://moi3d.com/forum/index.php?webtag=MOI&msg=8818.15 curve explorer
there where only numbers, i've change them to annotation text
1. after saving with annotations, reloading annotations will change positions !
2. crv - evaluateCurvature - understand it's trying to evaluate several connected control pts ?!?!?!
3. tg - evaluateTangent - shoudn't be perpedicular ?
4. evaluateDerivatives - what are those ? (1,2,3 - too far away, pointed direction)
with this script, arrows point different direction (I guess It's correct one, arrows are tangent*)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9781.13
EDITED: 5 Jul 2020 by CEMORTAN_TUDOR
Size: 35.6 KB, Downloaded: 85 times, Dimensions: 634x933px
8665.155 In reply to 8665.154
Hi Tudor,
There is a bug with the anchor point switching around when you save/reload annotation text block objects, it's fixed for the next beta.
I'm not sure what you're asking here.
No, a curve tangent is not perpendicular to a curve, it's the direction the curve is traveling in at that point, like this:
That would take a long time to explain, you could try some online descriptions like:
https://demonstrations.wolfram.com/TheDerivativeVectorsOfABSpline/
Or check out:
"NURB Curves: A Guide for the Uninitiated" by Philip J. Schneider
https://vintageapple.org/develop/pdf/develop-25_9603_March_1996.pdf
These values are vectors that represent directions, it maybe sounds like you're interpreting them as point location values instead of vector directions?
EDITED: 5 Jul 2020 by MICHAEL GIBSON
8665.156
restrictToLinePtDir
Restrict the user to only selecting points along the line defined by startPt and the vector dir. If projectAll is true, the user can select any point along the infinite line that goes through startPt in the direction specified by dir. If projectAll is false, the user can only select points along the line segment between startPt and startPt + dir.
false parameter is not working
- Tudor -
8665.157 In reply to 8665.156
Hi Tudor,
> restrictToLinePtDir - false parameter is not working
It's working ok for me over here.
Parameter "project all" true, test script:
script: var pp = moi.ui.createPointPicker();
pp.restrictToLinePtDir( moi.vectorMath.createPoint(0,0,0), moi.vectorMath.createPoint(1,1,0), true );
while ( 1 ) { if ( !pp.waitForEvent() ) break; }
result - point tracks along given line instead of tracking along viewport's cplane grid, and object snaps are also projected onto the line:
Parameter "project all" false, test script:
pp.restrictToLinePtDir( moi.vectorMath.createPoint(0,0,0), moi.vectorMath.createPoint(1,1,0), false );
result - point tracks along given line instead of the viewport's grid, but object snaps are not projected onto the line:
8665.158
Thanks ! next time I'll ask if it's working xD
I thought it will work in different way
_extendTangency 1.1
* added htlm
add functions + hotkeys
b - bothsides
a - join
f - flip sides (here I've needed ~ restrict line direction - not Togo opposite tangency direction)
script is not ended, but it has a good chunk of it, will return when i'll know more about html and moi basefunctions
- Tudor -
8665.159
how can i get difference between parallel frames ?
- Tudor -
8665.160 In reply to 8665.159
Hi Tudor,
Do you mean the difference in the origin points between 2 coordinate frames?
That would be like this:
var dx = FrameB.origin.x - FrameA.origin.x;
var dy = FrameB.origin.y - FrameA.origin.y;
var dz = FrameB.origin.z - FrameA.origin.z;
8665.161
between parallels - similar to distance of projection of 1 pt from 1 frame to another
- Tudor -
8665.162 In reply to 8665.161
Hi Tudor, sorry it's not clear to me what you're trying to do.
If it's something like transforming the coordinates of a point in global x,y,z coordinates into coordinates relative to a frame, that would be like this:
var local_x = frame.distancex( pt );
var local_y = frame.distancey( pt );
var local_z = frame.distancez( pt );
The .distancex, .distancey, and .distancez functions on a coordinate frame return the distance of a point in world coordinates along the x, y, or z axis direction planes of the frame.
If that's not it then I need a clearer description of what you're trying to do, it's hard to figure out what you're asking about if you don't provide some more details.
8665.163
bool operations of standalone curves that have different frames but are parallel to each other (ex circle at 0 0 0 and another at 1 1 1) -> to apply a move to second group(for difference will be subtract objectgroup) & do the bool
- Tudor -
8665.164
rect3pts with center
- Tudor -
Show messages:  1-4  …  85-104  105-124  125-144  145-164  165-184  185-204  205-224  …  365-372
