Lots of unkown
 1-14  …  95-114  115-134  135-154  155-174  175-194  …  355-372
8665.135 In reply to 8665.134
Hi Tudor,
> if i'm extracting curves, how shall i transfer back to edges ?
Sorry I'm not sure I understand this - you can call curve evaluate methods on an edge curve just like you can on a "standalone" curve.
One thing to be aware of is that a curvature break between 2 edge curves does not mean anything about the continuity of the surface at that point. For example:
8665.136
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*value
Numpad/ -> value/value
- Tudor -
8665.137
http://moi3d.com/wiki/V4Beta
Scripting:
Added additional script interface for Curve and CurveSegment objects.
For both Curves and CurveSegments:
wasn't any mention about edges, will try !
- Tudor -
8665.138
About align - 3d viewport -> I think it should be aligned along camera position - not along axis
8665.139 In reply to 8665.137
Hi Tudor,
Edge curves and "standalone" curves have the same curve interface object.
Can you show an example of what you mean?
8665.140
Unified under one command Union and Join ~ they do they same, need more testing
- Tudor -
8665.141
based on camera angle what's left/right/top/bottom
- Tudor -
8665.142 In reply to 8665.141
Hi Tudor, that's an interesting idea. But what if your camera angle is right near a switchover spot? That would probably mean that you could get in a situation where you move the camera a slight amount and get a big shift in the result.
8665.143 In reply to 8665.142
yes, but at the current align i have to guess what button should i press
for static i could change to orto views !
EDITED: 4 Jul 2020 by CEMORTAN_TUDOR
8665.144 In reply to 8665.143
Hi Tudor, you don't have to guess if you look at the x/y/z axis tripod display in the lower left corner:
8665.145
dont have them xD well, it was a suggestion(intuitively will be right and left - ! all we know what it means xD no x & y's - it was written right side ! why it haves weird xD ))
I'm in another propose script ~ isolate update
now - the way it works it now it isolates objects, next call unhides all
what i want - isolate to update on selected objects(ex: doing some operation on objects, isolate to work further), on deselect - call isolate - unhide all. for that i need a global variable ! as I've read scripts all variables are inside scripts (i'm still learning js)
benefits - hitting twice isolate to work further - not to much ~ clicking saving
8665.146
options vanilla - save current color style as default
I respect blender for community they've grow
Size: 199.9 KB, Downloaded: 127 times, Dimensions: 676x575px
8665.147
cplane as internal doesn't have options locating hotkeys reset, etc
I like pointpicker.addSnapPoint( startpt, moi.ui.getText('Closed snap') ); -> moi.ui.getText()
can it be fixed at a viewport camera position (aka : bottom right; wanna do mini helper for added hotkeys that i'm doing ~ https://youtu.be/8k2NGWrKbj4?t=1239 bottom right ) only when moved over show helper (new lines will be welcome) : personalized -> mb yes -> if u won't see growth in this direction ! (I know that u want viewport as clean as possible, asking for ~ a helper point/style without can be improved - need agreement )
this also can be applied to filters ( which I have to have opened browser to view which one is active - aka edg/faces/solids/so on)
- Tudor -
8665.148 In reply to 8665.145
Hi Tudor,
No, that's not how it works now. The way it works now is on the first call it saves a snapshot of the hide/show state of all objects to internal memory, then it does an isolate. The next time you trigger it, it restores things to the pre-isolate snapshot.
For example starting with 6 objects, these 4 are hidden:
Select this object:
Do Isolate, now it is the only one visible and the other 5 are hidden:
Do Isolate a second time, only the object that was visible when the first Isolate was done is visible, not the other 4 objects which remain hidden:
8665.149 In reply to 8665.146
Hi Tudor,
You can do that in MoI by saving a .3dm file with the colors set how you want, then set it as the startup template file under Options > General > Template file, the styles in that file will be used as your default ones when you start up MoI or when you do a File > New :
8665.150 In reply to 8665.147
Hi Tudor:
You can set up a shortcut key for cplane reset by putting in this on a shortcut key:
script: moi.view.resetCPlane();
Also a right-click on the View > CPlane button is a shortcut for reset.
There isn't any mechanism for displaying viewport text at a fixed screen location, I would recommend using a dialog for something that stays fixed on screen rather than a viewport display object.
8665.151 In reply to 8665.147
Hi Tudor,
It would be a good idea to have an additional indicator for a filter being active up here somewhere, I've added that to my list of things to look into after v4 is finished.
8665.152
1. About isolate - it's not my idea !
It comes from softimage - it has several layers of hidden properties
1. render - can overrides lower layers
2. groups - individual only manual changed - overrides lower layers
3. layers ~ similar to objects name in moi
2. individuals ~ moi - selected object hide
1. isolate - lowest level (can tunnel from isolate to isolate until 1 object will remain - nothing else then exit)
2. Ini - thanks
3. Cplane - my idea is to combine hotkeys under groups, later expand them (c only for cplane, hotkeys after part of cplane grouping - aka reset)
~ on rest of scripts there's a waitable object where it can be placed, here i can't setup under a group
- Tudor -
8665.153 In reply to 8665.152
Hi Tudor,
Sounds very complicated.
Yes, the cplane's event loop happens to be implemented with C++ code inside moi_lib.dll instead of in
script code so there isn't any way you can alter that one. You would have to set up your own
script for it instead.
8665.154
now i'm more confused
expanding http://moi3d.com/forum/index.php?webtag=MOI&msg=8818.15 curve explorer
there where only numbers, i've change them to annotation text
1. after saving with annotations, reloading annotations will change positions !
2. crv - evaluateCurvature - understand it's trying to evaluate several connected control pts ?!?!?!
3. tg - evaluateTangent - shoudn't be perpedicular ?
4. evaluateDerivatives - what are those ? (1,2,3 - too far away, pointed direction)
with this script, arrows point different direction (I guess It's correct one, arrows are tangent*)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9781.13
EDITED: 5 Jul 2020 by CEMORTAN_TUDOR
Size: 35.6 KB, Downloaded: 85 times, Dimensions: 634x933px
Show messages:  1-14  …  75-94  95-114  115-134  135-154  155-174  175-194  195-214  …  355-372
