Lots of unkown
 1-2  …  83-102  103-122  123-142  143-162  163-182  …  363-372
8665.123 In reply to 8665.122
DisableOnSrfInOrtho
- Tudor -
8665.124 In reply to 8665.123
Hi Tudor, the runtime script property for that one is moi.drawingAids.disableOnSrfInOrtho
8665.125
Thanks !
script: /* SurfaceInOrtho */ moi.drawingAids.disableOnSrfInOrtho = !moi.drawingAids.disableOnSrfInOrtho
- Tudor -
Message 8665.126 deleted 23 Jul 2020 by CEMORTAN_TUDOR
8665.127
Align Hotkeys
w - top
s - bottom
a - left
d - right
q - Vertical Center
e - Horizontal Center
- Tudor -
8665.128
wanna improve the align script !
my question is how do i get pointpicker.basept(or value of pointpicker after alignment without clicking) when I'm pressing second hotkey ( let's say I've aligned top, now I need right side -> not to run script twice )
- Tudor -
8665.129 In reply to 8665.128
Hi Tudor, the current point for the pointpicker can be accessed using the .pt property on it.
There is also a .cplane property for getting the construction plane (the grid plane) for the pick, and also .ptframe for getting a coordinate frame with its origin at the current point and the frame's axes in the cplane directions.
8665.130
is that if clicked?
anything without clicking ? cuz if I click something, scripts ends it's action
otherworlds I need current pointposition without click
if (!wasAnyHotkey) {
moi.command.setOption( 'AlignMode', 'VerticalLeft' );
factory.setInput( 2, 'VerticalLeft' );
factory.update();
wasAnyHotkey = true;
else {
//here i need help !
pointpicker.pt = pointpicker.ptframe.origin ;
factory.commit();
DoAlign();
EDITED: 2 Jul 2020 by CEMORTAN_TUDOR
8665.131 In reply to 8665.130
Hi Tudor,
> is that if clicked?
No, it's available anytime the pointpicker has been able to get a point, like with mousemove.
Yes, that's how the regular Align command is supposed to work. When you click a point a 'finished' event will be triggered, and this part of the script exits the even loop when it sees that;
	while ( 1 )
		if ( !pointpicker.waitForEvent() )
			return;
>>>		if ( pointpicker.event == 'finished' )
>>>			break;
If you don't want the script to end when a point is clicked you would want to modify what it does with the 'finished' event, like ignore it.
8665.132
Thanks Michael
Align Hotkeys
w - top
s - bottom
a - left
d - right
q - Vertical Center
added
align corners
ex: w+a/w+d/s+a/s+d
- Tudor -
8665.133
based on
https://github.com/arekm/rsdoc-to-sat
Convert DesignSpark Mechanical DSM rsdoc file to sat file which can be loaded into MoI3d
Installation -> python3
drag & drop rsdoc file(s) onto rsdoc-to-sat.py file
.sat file(s) will appear in the same directory as rsdoc file(s).
author went via winreg path, i've changed path inside script to full path ~
inside script change path of sabsat to full path of SabSatConverter.exe (it comes with full DSM installation)
sabsat = "C:\\Program Files\\DesignSpark\\DesignSpark Mechanical 4.0\\SabSatConverter.exe"
- Tudor -
8665.134
o hayo !
v4 new future crv.evaluateCurvature
I'm thinking about script for edge loop up to ~ broken curvature on a brep (on curve will be a sharp corner)
if i'm extracting curves, how shall i transfer back to edges ?
- Tudor -
8665.135 In reply to 8665.134
Hi Tudor,
Sorry I'm not sure I understand this - you can call curve evaluate methods on an edge curve just like you can on a "standalone" curve.
One thing to be aware of is that a curvature break between 2 edge curves does not mean anything about the continuity of the surface at that point. For example:
8665.136
Shortcuts for manipulation:
Fillet; Inset; Shell ; Offset(Brep)
Numpad+ -> value + value/2
Shift+Numpad+ -> value + value/10
Numpad- -> value - value /3
Shift+Numpad- -> value + value/10
Numpad* -> value*value
Numpad/ -> value/value
- Tudor -
8665.137
http://moi3d.com/wiki/V4Beta
Scripting:
Added additional script interface for Curve and CurveSegment objects.
For both Curves and CurveSegments:
wasn't any mention about edges, will try !
- Tudor -
8665.138
About align - 3d viewport -> I think it should be aligned along camera position - not along axis
8665.139 In reply to 8665.137
Hi Tudor,
Edge curves and "standalone" curves have the same curve interface object.
Can you show an example of what you mean?
8665.140
Unified under one command Union and Join ~ they do they same, need more testing
- Tudor -
8665.141
based on camera angle what's left/right/top/bottom
- Tudor -
8665.142 In reply to 8665.141
Hi Tudor, that's an interesting idea. But what if your camera angle is right near a switchover spot? That would probably mean that you could get in a situation where you move the camera a slight amount and get a big shift in the result.
Show messages:  1-2  …  63-82  83-102  103-122  123-142  143-162  163-182  183-202  …  363-372
