Lots of unkown
 1-11  …  72-91  92-111  112-131  132-151  152-171  …  372
8665.112 In reply to 8665.110
Hi Tudor,
re: why is so ?
The point that your mouse picks is done by an intersection between the screen ray and the construction plane. In the 3D view if you are looking at the construction plane at an steep angle it is pretty easy to have a point far off towards the horizon with only a small movement in screen space:
8665.113 In reply to 8665.112
i'm trying also via move
pointpicker.restrictToPlane( moi.ui.getActiveViewport().targetFrame , true );
am I doing smt wrong ?
same result
I want a screen move*
8665.114 In reply to 8665.113
Hi Tudor, one method you can use for that is the script here which sets the construction plane to the view frame:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2599.8
Can you post the full script?
8665.115
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.92
move + a
*about history, I dont have enough time to go deep into it, I thought will be welcome some kind of history - *Notes
*smallest fillets i'll work on it more, found some scripts and posts on v4 version that might help - curve explorer and ordered curves
*point position - yes, x,y,z somewhere in moi explorer without scripting
*about normals - seems smt new to v4, like it, when offsetting u getting notification of a normal plane to extrude ~ it's the same as perpendicular to a point, normals for me sounds more familiar - was searching for that terminology
some more that i'm interested
moi htlm functions if there's a collection of them - aka moi:options; moi:text; moi:Numeric .. so on
hidden moi factories xD discovered that arrow and might be others same category (aka - dimensions arrowhead)
wishes
ctrl clone -> to pick last duplicate todo modifications - as an option ? often it comes that i have to change position/size so on
there's a script
script:var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
I dont understand it - doesn't respond to ctrl clone/dublicate as well - only to scripts ?
~ buggy
alt + right click - shouldn't repeat last command -> It's supposed to be zoom
and Thanks !
- Tudor -
8665.116 In reply to 8665.115
Hi Tudor, sorry it's hard for me to follow what parts you are just describing and what parts you are asking questions about.
> move + a
It seems to be working ok over here - I push a when picking the target point and it then tracks along the view plane. Can you tell me what steps you are using where you're seeing a problem?
There isn't any documentation for these currently, sorry. But if you have questions about a particular one I can tell you about it. For <moi:option> that's like a regular HTML <option> except it gets the inner text to display by a textid="" value that is looked up from the current language's string table.
<moi:Text> is like a <span> tag but it fills in its text by the given textid="" value looked up from the current language's string table.
<moi:NumericInput> is similar to an HTML <input> but for numeric values.
> wishes
Hmm, yes it's because object dragging doesn't run as a regular command does and so it's missing some of the setup/cleanup type things that happen with regular commands. I'll see about fixing this.
> ~ buggy
Any right click will repeat the last command, (or push the "Done" button if that is visible), it's only an Alt + Right drag that does a zoom, not a click without dragging.
8665.117
O hayo !
used same script
I'll give a preview as file
It should act like viewport cplane
- Tudor -
8665.118 In reply to 8665.117
Hi Tudor, and when are you pushing the 'a' key to trigger your restrict to the view plane? Your code only handles it for the second point pick.
Message 8665.119 deleted 28 Jun 2020 by CEMORTAN_TUDOR
8665.120
thanks ! I was missing ordering !
- Tudor -
8665.121
I know in config it's possible to turn project orto, is it possible to script toogle without restarting ?
- Tudor -
8665.122 In reply to 8665.121
Hi Tudor, do you mean this setting in moi.ini ? :
ProjectOsnapsInOrthoViews=y
That property can be set by script at runtime at moi.drawingAids.objectSnapProjectInOrthoViews so to toggle it try this:
moi.drawingAids.objectSnapProjectInOrthoViews = !moi.drawingAids.objectSnapProjectInOrthoViews;
8665.123 In reply to 8665.122
DisableOnSrfInOrtho
- Tudor -
8665.124 In reply to 8665.123
Hi Tudor, the runtime script property for that one is moi.drawingAids.disableOnSrfInOrtho
8665.125
Thanks !
script: /* SurfaceInOrtho */ moi.drawingAids.disableOnSrfInOrtho = !moi.drawingAids.disableOnSrfInOrtho
- Tudor -
Message 8665.126 deleted 23 Jul 2020 by CEMORTAN_TUDOR
8665.127
Align Hotkeys
w - top
s - bottom
a - left
d - right
q - Vertical Center
e - Horizontal Center
- Tudor -
8665.128
wanna improve the align script !
my question is how do i get pointpicker.basept(or value of pointpicker after alignment without clicking) when I'm pressing second hotkey ( let's say I've aligned top, now I need right side -> not to run script twice )
- Tudor -
8665.129 In reply to 8665.128
Hi Tudor, the current point for the pointpicker can be accessed using the .pt property on it.
There is also a .cplane property for getting the construction plane (the grid plane) for the pick, and also .ptframe for getting a coordinate frame with its origin at the current point and the frame's axes in the cplane directions.
8665.130
is that if clicked?
anything without clicking ? cuz if I click something, scripts ends it's action
otherworlds I need current pointposition without click
if (!wasAnyHotkey) {
moi.command.setOption( 'AlignMode', 'VerticalLeft' );
factory.setInput( 2, 'VerticalLeft' );
factory.update();
wasAnyHotkey = true;
else {
//here i need help !
pointpicker.pt = pointpicker.ptframe.origin ;
factory.commit();
DoAlign();
EDITED: 2 Jul 2020 by CEMORTAN_TUDOR
8665.131 In reply to 8665.130
Hi Tudor,
> is that if clicked?
No, it's available anytime the pointpicker has been able to get a point, like with mousemove.
Yes, that's how the regular Align command is supposed to work. When you click a point a 'finished' event will be triggered, and this part of the script exits the even loop when it sees that;
	while ( 1 )
		if ( !pointpicker.waitForEvent() )
			return;
>>>		if ( pointpicker.event == 'finished' )
>>>			break;
If you don't want the script to end when a point is clicked you would want to modify what it does with the 'finished' event, like ignore it.
Show messages:  1-11  …  52-71  72-91  92-111  112-131  132-151  152-171  172-191  …  372
