Thanks James.
I've fallen behind on all the node editor posts, due to too much work/family duties, and did not realize your prior activity:-)
Currently looking for Surf convert .js
Maybe it is hiding in a macro?
OK, it is in a macro, but I still need isoCrvs.js :-)
OK, basicfunctions goes under libs subdirectory in extensions.
Also, should add to nodeeditor wiki docs to check out macros, if a node is red (missing).
OK, do Karsten's menu cleanup from here:
 http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Then do the object2.js update from James.
Now Jame's Truchet.nod runs.
To fix Jame's RandomWrap7.nod, replace IsoCrvs programming rectangle with IsoCrvs rectangle from construct2 menu.
Delete the old IsoCrvs rectangle, and Save the menu-updated node to RandomWrap7.nod.
(should add to wiki)
(Note, IsoCrvs was in a test menu area, and Karsten moved it to construct2 menu.)
