common chamfer problem
8662.1
as I've noticed it's problematic on concave/convex edges to make an uniform chamfer as blending those 2 together !
EDITED: 2 Nov 2017 by CEMORTAN_TUDOR
Size: 46.3 KB, Downloaded: 37 times, Dimensions: 1219x433px
8662.2 In reply to 8662.1
Hi Cemortan, so unfortunately that's just how Chamfers are set up to work in CAD programs in general, they're defined by offset distances of each of the surfaces the edge being chamfered belongs to and that produces the kind of result you are showing there. You should see the same thing in other CAD programs as well.
If you chamfer all the edges by selecting the whole object rather than just the upper ring, then there will be corner juncture patches where chamfers or fillets of different widths collide into each other like this:
8662.3 In reply to 8662.2
i thought u are unique :)
