How to delete overlapping Points?
All  1-2  3-5
8634.3 In reply to 8634.2
Oh what a powerful Command!
But in the corners it's not realy useable, cause you get round corners after use.
But, in most cases it's realy well!
Thanks alot.
8634.4 In reply to 8634.3
Hi B-W-Design.
@You : "...But in the corners it's not realy useable, cause you get round corners after use..."
I don't see this problem with curves imported from Affinity Designer. Corners remains corners also after a Rebuild.
Cheers.
Separate for have curves and straight lines separated so you can rebuild only curves! :)
Show messages: All  1-2  3-5
