Moi + Affinity : Moi for 2D workflows
 1-17  …  38-57  58-77  78-90
8629.78 In reply to 8629.76
Not sure if it's native. I bound it to a Shortcut Key.
LINK: http://moi3d.com/forum/index.php?webtag=MOI&msg=6099.1
script: /* Copy PDF format to clipboard */ moi.geometryDatabase.copyToClipboardPDF();
EDIT: Hi Michael!
8629.79
Thanks for the video Danperk - looks good.
I’m wondering if one could bypass the dialogue box
with a script/ shortcut that has the same pdf export settings shown in the video…
8629.80 In reply to 8629.79
@stefano,
Yes you can pass in some options to use specific settings and not show the dialog, check out here look under "Scriptable options for PDF/AI export."
http://moi3d.com/forum/index.php?webtag=MOI&msg=6579.1
EDIT: fixed wrong link
EDITED: 14 Aug 2024 by MICHAEL GIBSON
8629.81 In reply to 8629.77
Thx for the info! (Michael & Danperk)
Advantage of the "Native" export(s) is that you can have a library of "PDF" files ready to drag & dropped" to Affinity! ;)
You have an Free Online "Illustrator;" https://www.vectorpea.com
tones of exports (not yet found if CTRL +C Crtl +V is working to MOi! :)
but of course normal export PDF or SVG are working! (curioussly not Ai for Moi)
EDITED: 14 Aug 2024 by PILOU
Does exist an ClipBoard Import Ai format script to Moi ? Or It's implicit ?
8629.83 In reply to 8629.82
@Pilou,
It's implicit - if the system clipboard has data in PDF, SVG, or AI3 formats that can be pasted into MoI using the regular Ctrl+V or Edit > Paste commands.
The reason why the other direction is separated out is because it shows a dialog box.
8629.84 In reply to 8629.82
-"Does exist an ClipBoard Import Ai format script to Moi ? Or It's implicit ? "-
It works with Copy/Paste from Adobe Illustrator, but not sure about other vector programs.
8629.85 In reply to 8629.80
-"Yes you can pass in some options to use specific settings and not show the dialog, check out here look under "Scriptable options for PDF/AI export."-
I couldn't see that information in the link you posted, I'm getting old, it could be me.
8629.86 In reply to 8629.85
@danperk - Oops I put the wrong link there, try "Scriptable options for PDF/AI export" here:
8629.87 In reply to 8629.86
Got it, Thanks!
the file Ai from Vectorpea not reloadable by Moi or Affinity 1 (a simple rectangle)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/nouveau_projet.ai
8629.89 In reply to 8629.88
Looks like it's a newer style AI file that is actually a PDF file, not an AIv8 type file that MoI supports.
You can rename it to nouveau_projet.pdf and open it in Adobe Reader but it appears to be an empty page.
8629.90 In reply to 8629.89
yep must be recent version ...in any case reloadable by Vectorpea... for other formats if necessary! :)
Show messages:  1-17  18-37  38-57  58-77  78-90
