Moi + Affinity : Moi for 2D workflows
 1-2  3-22  23-42  43-62  63-82  83-90
8629.43 In reply to 8629.42
Hi STEFAN.
Oh yeah...ZSurf is very useful and in many cases is the right choice!
I have used it sometimes in the past with good results.
But because here I'm trying always to find "old and new" workflows for Moi and Affinity I'm more interested in playing with curves rather than surfaces.
Anyway, you're right. In many cases ZSurf generates surfaces with a good smoothness, and the Iso curves that I can extract are better than those
generated from "HeightMap" script.
Ciao!
Stay tuned for new stuff involving Moi and Affinity :)
Hi Marco and all,
just took your tiger drawing into Art Text 3. I really like what one can do with it. :-)
P.S. i added also one Penrose tiling image, done with MoI and Art Text 3, to the MoI Gallery.
Best regards
8629.45 In reply to 8629.44
Hi Stefan!
Very nice!
@You "...your tiger drawing..."
As I said in my original post the tiger is not mine. I get it in Freepik.com
(https://www.freepik.com/free-vector/animals-tribal-tattoo-collection_1168322.htm#term=tiger&page=1&position=5)
Thanks for sharing!
Stay tuned...I hope to upgrade soon my scripts for 2D Workflows. (bug fixing)
Ciao!
8629.46 In reply to 8629.44
P.S. I only tweaked the tiger a little bit with Affinity Designer to make some cleanup, then I exported it in PNG and then I have used the png for
my 2D Workflow tutorial (original post : http://moi3d.com/forum/index.php?webtag=MOI&msg=8629.39)
Ciao!
Thanks for the info Marco!
I overlooked that the original image was from there...
Best regards
Hi Michael.
I'm pretty sure that you already answered me a long time ago, about this question, but I don't remember where is your answer.
I've searched trough the forum by I didn't find what I'm looking for.
The question is this :
If we simply take into account the "speed of execution" factor, can we state that the code executed inside a the "hmtl" page of a command
or inside a script placed into the "scripts" folder, is faster (and many times faster) the the execution of "js code" present in the "js" counterpart of command's html ?
I ask you this because I have in mind to turn the next version of my "script for 2D workflow" from "script" into "command" just in order to
handle more easily the various working mode of that scripts.
For what I've experienced and learned I've seen that the "js" code executed inside the Hml file of command is much more faster that the counterpart executed into the "js" file of the command :
For example consider the "ScaleIndividual" commands that Max wrote times ago :
1) the original version of Max Smirnov :
get it at https://drive.google.com/open?id=1waO3TgOQSUl2ZIBJ8adixPz5Qes_ja21
2) A version that I have modified and that do the main task into the "js" code inside the Html file of the command :
get it at https://drive.google.com/open?id=1N6qWe_lzyJA-aTOrmESLRPhzky_XHhoB
Why the 2nd version, is much more faster than the first (to make a good test you have to select many objects, I tested with hundreds) ?
This is the code of the original version of ScaleIndividual.js and ScaleIndividual.htm :
#include "GetObjects.js"
#include "WaitForDialogDone.js"
function ScaleObject( obj, factor )
	var center = obj.getBoundingBox().center;
	var list = moi.geometryDatabase.createObjectList();
	list.addObject( obj );
	var factory = moi.command.createFactory( 'scale' );
	factory.setInput( 0, list );
	factory.setInput( 1, center );
	factory.setInput( 2, factor );
	factory.commit();
function DoIndividualScale()
	var objectpicker = moi.ui.createObjectPicker();
	if ( !GetObjects( objectpicker ) )
		return;
	var objects = objectpicker.objects;
	moi.ui.beginUIUpdate();
	moi.ui.hideUI( 'SelectPrompt' );
	moi.ui.showUI( 'OptionsPrompt' );
	moi.ui.showUI( 'options' );
	moi.ui.endUIUpdate();
	if ( !WaitForDialogDone() )
		return;
	var scalefactor = moi.ui.commandUI.factor.value;
	for ( var i = 0; i < objects.length; ++i )
		var obj = objects.item(i);
		ScaleObject( obj, scalefactor );
DoIndividualScale();
<html>
	<body class="commandbody">
		<div class="commandheader">
			<div id="SelectPrompt" class="commandprompt">Select objects to scale</div>
			<div id="OptionsPrompt" class="hiddencommandprompt">Scale options</div>
		</div>
		<div id="options" class="hiddencommandoptions">
			<table>
				<tr>
					<td>Scale factor:</td>
					<td><moi:NumericInput id="factor"/></td>
				</tr>
			</table>
		</div>
		<moi:CommandDoneCancel />
	</body>
</html>
And this is the code of my modified version of ScaleIndividualMainThread.js and ScaleIndividualMainThread.htm :
function DoIndividualScaleInit() {
		return;
		return;
	moi.ui.commandUI.DoIndividualScale(objects);
DoIndividualScaleInit();
<html>
	<head>
		<script>
			function ScaleObject( obj, factor ) {
				factory.commit();
			function DoIndividualScale(objects) {
				for ( var i = 0; i < objects.length; ++i ) {
		</script>
	</head>
		</div>
			<table>
				<tr>
				</tr>
			</table>
		</div>
	</body>
</html>
Thanks a lot for the support :)
Have a nice day.
Ciao!
Marco (mkdm)
EDITED: 4 Nov 2017 by MKDM
P.S. Michael, I will read your answer in five-six hours because now I have to go :)
8629.50 In reply to 8629.48
Hi Marco,
> executed inside a the "hmtl" page of a command or inside a script placed into the "scripts"
For V3 yes that's true - the .js code is run in a separate process and uses inter-process communication on every MoI API call. The reason for this is it makes it impossible for the script to freeze MoI if it runs in an endless loop or something like that, the worker process can be torn down independently from the script's cooperation.
But the inter-process communication has a performance penalty. The regular default commands in MoI never use script to do heavy calculations in loops or things like that, and so are ok with that.
Code in the HTML side runs in the main process thread and so it doesn't have that same overhead.
For V4 this will be different though, in V4 the .js script will be run on the main thread and not on a worker thread anymore and so in v4 there won't be any difference for which file the code is contained in.
8629.51 In reply to 8629.50
Thank you very much Michael for reminding me this behaviour.
Ciao :)
Hello everyone!
I'm sorry for the uppercase but THIS IS THE LONG AWAITED DAY for all passionate pro artists/amateurs of 2D workflow/vector things!!
THE DAY has come :)
AFFINITY DESIGNER is ready for iOS!!!!!!
Still not of App Store but you can download here if you're on iPad: https://itunes.apple.com/us/app/affinity-designer/id1274090551?mt=8
Yep the challenger of Procreate! :)
Affinity Designer for iPad - official video from Affinity on Vimeo.
8629.54 In reply to 8629.53
This is a GREAT day for all the iPad crowd!!
Anyway, Procreate and Affinity Designer are not competitor at all.
They are focused on very different things.
But...what a wonderful DUO!!!!!
And don't forget Affinity Photo!
Great things for 2d graphics :)
These apps destroys everything on Android/Windows mobile side!
8629.55
Yes, its THE Adobe Illustrator challenger...
8629.56 In reply to 8629.55
But with the golden bonus that actually there isn't any iOS version of Adobe Illustrator!!
So actually Affinity Designer is the "Lion King" for vector things on iOS (and IMHO for mobile in general).
It was launched only some days ago so actually is still young and needs a certain amount of bug fixes obviously, and in fact I have already reported some bugs on Affinity Forum, but for what I've seen in the last three days of hard use it's really a game changer for all 2D graphics on mobile.
It's the missing link between Procreate and Affinity Photo.
Procreate (or Artstudio Pro) + Affinity Designer + Affinity Photo = almost ALL you need for a REAL professional 2D graphic pipeline on Mobile!
This is what I'm experiencing with my iPad Pro 12.9 2017.
Cheers.
...as third thief free Gravit Designer ;)
https://www.designer.io
Hello Stefan and everyone!
This time I'm going to show you certainly nothing "never seen" or "new" or "special" but maybe a reminder of what we can do thanks with the "Flow" command, especially regardin my beloved "2D workflows" involving Moi and (not in this case) Affinity Designer.
I will play with a simple "Text curve" created with the "Text" command.
You can use any font.
The.3dm test file: http://take.ms/2BAlw
The video tutorial: http://take.ms/wzB6z
In the first part of the video I will use only simple curves, open and closed.
As you will see if we use a "closed" destination curve, sometimes we need to apply first the "Flip" command on the destination curve to get the correct result.
In the final part of the video I will show you some simple scenario with more complex deformations.
In that case I will not apply the "Flow" command directly on the source "Text" curve but on its "3D" counterpart.
I don in this way otherwise I will not get the correct result.
Then I will use the deformed 3D objesct to extract the resulting text curves.
Remember these two things when you have to play with the "Flow" command using surfaces for both "source" and "destination":
1) The "topology" of the surfaces.
2) We will get better results if we work on "trimmed" surfaces using the "ShrinktrimmedSrf" command.
I hope I made myself clear enough with these simple example :)
You can text on you r own more complex things.
Ciao!
Hi Marco,
very good! Thanks a lot!
8629.60 In reply to 8629.59
My pleasure :)
That was only a very simple example of how Moi, used in the right way, can be a great helper for any professional 2D workflow and "vector related" things.
Consider that sometimes I leverage on Moi to create also "supporting graphics" for my digital painting experimemts.
This is something that it's hard to see "chained" with a 3D Nurbs modeler...
Marco (mkdm)
Cool tut...
Moi can do Texts also on 3D volume! ;)
My Moi French Site My Gallery
8629.62 In reply to 8629.61
Yes!! :)
Show messages:  1-2  3-22  23-42  43-62  63-82  83-90
