Moi + Affinity : Moi for 2D workflows
 1  2-21  22-41  42-61  …  82-90
You can use the native "ExplodeMove" function inside Moi! ;)
EDITED: 15 Oct 2017 by PILOU
8629.3
I second this workflow. I often use MoI for easy creation of complex shapes, then use this script to copy the result to the clipboard as a PDF, and simply paste into Affinity Designer:
script: /* Copy PDF format to clipboard */ moi.geometryDatabase.copyToClipboardPDF();
— Metin
metinseven.com — visualization • illustration • animation • 3D (print) design
8629.4 In reply to 8629.3
Hi Metin.
@You : "...I second this workflow..."
Moi + Affinity Designer = Great fun and professional results!
Cheers.
8629.5 In reply to 8629.2
Hi Pilou.
@You : "...You can use the native "ExplodeMove" function inside Moi!..."
...ok...thanks for the reminder but...I don't see the connection with my first post :)
Anyway, thanks.
Ciao.
Hi everyone!
New "quick & dirt" little tutorial coming soon...
From this (in Moi)....
To this (in Affinity Designer)
Cheers!
8629.7 In reply to 8629.6
Nice! Thanks for creating the tutorials, Marco! Appreciated.
— Metin
8629.8 In reply to 8629.7
You're welcom Metin.
Tonight I hope to publish that new little tut and also another one.
Stay tuned.
Ciao.
Hi everyone!
As promised, here's the second "quick & dirt" video tutorial involving the great duo "Moi & Affinity Designer"
This time I've used only standard Moi commands.
I hope you like it.
This is the video : http://take.ms/cgk03
Bye!
8629.10 In reply to 8629.9
I do!
Remarkable - thanks.
Mike.
8629.11 In reply to 8629.9
Brilliant! Thanks,
eric
Thanks a lot Mike and Eric for feedback! Much appreciated!
New tuts will come soon...
I'm trying to explore this 2D workflow without following a predetermined path.
Just the imagination.
Cheers!
Hi everyone!
Here's the third video tutorial involving the great duo "Moi & Affinity Designer".
This time I've used a bunch of custom commands/scripts.
You can get them here : http://take.ms/MOfaEo
Unpack the archive and you will get these commands : PatternSelection and Randomize and these scripts : CenterAtOrigin and RandomDeselect
I hope you like it.
The final results is a little bit messy but I wanted to give you in a few minutes just an example of how to create a "pseudo-3d" geometric background.
This is the video : https://drive.google.com/open?id=0BwR81vxCXRhSOHh2TTZ6REQxcTQ
P.S. about at position 8:18 of the video you will see my "FilterCurveByLength" command.
I'm almost finished with it and soon I hope to publish the final 0.5 beta version.
Bye!
Marco (mkdm)
Very creative!
8629.15 In reply to 8629.14
Hi Pilou.
Thanks a lot for appreciation!
New tutorials soon :)
Have a nice day.
Great tutorials Marco!
And thanks for getting me started on Affinity Photo. After using the trial for a week, I purchased it and have used it for two weeks. My typical workflows for photo retouching have been greatly reduced and simplified. No more Photoshop for me! Affinity kept enough of the basic PS UI so I didn't feel I was learning a new program. But the way they simplified operations makes it fun to use, much in the same way MoI is fun to use. Affinity feels like it was designed by people who actually use and enjoy the program. PS now feels clunky, over complicated, and out-dated.
I'll try Affinity Designer when they get around to adding Offset Contours, a must have for my workflow. Then we'll see if Affinity can tear me away from Corel Draw :)
Gravit Designer for free 2D Drawing for replace Illustrator! ;)
https://www.designer.io
8629.18 In reply to 8629.17
You mean to replace Affinity Designer... :-)
http://basangpanaginip.blogspot.de/2006/07/worlds-most-photorealistic-vector-art.html
8629.19 In reply to 8629.16
Hello Ed!
Thank you very much for your kind words! Much appreciated.
As I said in some of my previous posts, I'm not a professional artist, and computer art isn't my main job,
but I'm a great enthusiast of anything related to CG for may years now, both 2D and 3D,
and for what I've experienced so far I can say that very rarely I've seen a software with all the characteristics of the Affinity suite.
Affinity Designer and Photo are cheap, fun, easy, well designed, with good performance and with modern UI.
For my daily job I often use them coupled with Moi, to design mockup and UI for Android Apps and the results are always very good.
With that said it's also true that Affinity suite is still young and must grow in many aspects.
For example "Symbols" in Designer are not yet bug free, or performances are good but not comparable with PS,
or it lacks Tracing capabilities, or for example Affinity Photo has not so good painting capabilities, and other aspects.
But I've seen here and there on YouTube and web in general, many artists that are getting great results with the Affinity suite.
For example, I don't know if you already knows it, but here you can find state of the art tutorials for Affinity Photo :
https://www.youtube.com/watch?v=ejM8Xp06Zug&list=PLjZ7Y0kROWitLXsh6z4Z3qBYCS6xoIXHN
Anyway, I will continue to explore the possibilities offered by the "great duo" Affinity Designer + Moi,
because in the last decade I haven't seen no other software under 60 USD capable to be so close, so close....to the unparalleled Moi,
both regarding workflow and easy to use (and fun).
Cheers!
8629.20 In reply to 8629.17
Hi Pilou.
Thanks for the tip!.
I've tested gravity designer for fun some weeks ago and I can say that it's a very useful and well designed web software.
And it's free.
But for my job I've experienced that it can't really fight against Affinity Designer.
And I think that Illustrator, although it is outdated and very expensive, is still undoubtedly many miles away, in many technical respects.
Ciao :)
Hi everyone!
Let's go with the fourth tutorial : LETTERING ON STEROIDS!
In this tutorial we will see how to "enrich" a letter using both Moi and Designer,
and how to use Designer's "Symbols" to manage instances.
As usual this is only a very simple example. The possibilities are endless!
For this tutorial I've used only standard Moi commands.
This is the video : http://take.ms/VEV5G
See you for next tutorial!
Ciao.
Show messages:  1  2-21  22-41  42-61  62-81  82-90
