Cross Section script or node
 1-2  3-21
8626.3 In reply to 8626.2
Karsten your a star,
works a treat better than I had imagined so much adjustment.
It just shows how useful the node editor is.
So again I in your debt.
Many thanks
Barry
8626.4 In reply to 8626.3
No problem - gladly!
Karsten
8626.5 In reply to 8626.2
Very, very nice.
Mike.
8626.6 In reply to 8626.2
Karsten....you rock!!!
What can I say ?
This is one of the coolest node I've seen so far!!!
As a sort of thank you please accept a little video of this simple experiment : http://take.ms/qEGbZ
Thank you very much.
Ciao!
Marco (mkdm)
EDITED: 12 Oct 2017 by MKDM
8626.7 In reply to 8626.2
P.S. Your last "work" also open a new kind of interesting possibilities!
Thanks!
8626.8 In reply to 8626.2
Hi karsten.
Damn!...how fun it is ??!!!
And it has also very acceptable performance.
This is a video of "section" with a scene made by about 14000 control points : http://take.ms/G2bww
Cheers.
Animated cut sections indeed!
8626.10 In reply to 8626.8
Hello Marco,
eehm - only a few nodes, nevertheless many thanks for the beautiful video. Maybe others need someday also a section, then no Explanation is needed.
Have a nice day
Karsten
p.s.: A quartz node in combination with a boundingbox for the range would also worth an Experiment. Important is to have fun:-)
8626.11 In reply to 8626.10
Hi Karsten.
You're welcome!
@You : "...A quartz node in combination with a boundingbox for the range would also worth an Experiment..."
Perfect! This is exactly what I've thought while I was playing with this experiment.
An "automatic" range detection would be very very useful.
Is the same approach I have applied to my (almost done) new script "FilterCurveByLength", that I hope to publish soon,
where I calculate automatically the "min" and "max" range for filtering.
Cheers!
8626.12
Hi Barry and Friends
Without taking anything away from Karsten's instructions, place the same solution
last night I realized ;
Karsten was no doubt much faster ...
This morning I took his post in the forum
file at this link:
http://www.mediafire.com/file/n4dtgc19kwwsf44/Intersect_test.rar
You may want to create a Macro Cross Section
in a very easy way-
have a nice day
alberto
8626.13 In reply to 8626.12
Hello Al,
I saw you have already used the bounding box. That's good!
Have a nice Weekend
Karsten
8626.14 In reply to 8626.12
Hi AL!
Thanks a lot for sharing.
Very cool stuff!
Bounding box is very useful!
Ciao.
8626.15 In reply to 8626.2
Hi Karsten,
thanks for very useful script. I have a problem with nodeditor probably, because if I start latest (v. 0.97) nodeeditor which I extracted after a long time into nodeeditor folder and load the node, so SAVE, APPLY, RUN and STEP buttons become gray and I cannot find out the reason of such behaviour.
Thank ýou for any help.
Mik
8626.16 In reply to 8626.15
Hi Mik.
I've already solved the same issue.
Get this zip archive : http://take.ms/ayOez
unzip it and copy the whole content into "C:\Program Files (x86)\MoI 3.0\ui\nodeeditor.v.0.97.2017.10.05\nodes\extensions"
or wherever you have the 0.97 version of NE.
You should get this content :
Also ensure that the very last lines of JS code into "index.html" file of 0.97 NE are these :
loadScripts('core','lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes','macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs','*');
loadScripts('nodes/extensions','*');
loadScripts('core','init, ext.*');
After that you should run all latest nodes without issues.
I solved in this way.
8626.17 In reply to 8626.16
Hi Marco,
this is it! It works perfectly now.
Thanks a lot.
Ciao
M
Why not post the entiere node Editor pakage with the new node ?
I suppose that a Zip file of it takes 2 seconds
It's not ecologic but that avoid any headache of version for the user! :)
If user is interested by the result he copies the .nod in its repository of nodes!
8626.19 In reply to 8626.18
Hi Pilou.
@You : "...It's not ecologic but that avoid any headache of version for the user! :)..."
LOL LOL LOL :)
Want to have fun ? Read all the posts I wrote about this argument (keep things organized, repository, versioning..)
I feel like a voice in the wilderness :)
But...no problem!
I have decided to take it easy ;)
Bye.
8626.20 In reply to 8626.19
You are not alone in the space! :)
8626.21 In reply to 8626.20
Cheers!
Show messages:  1-2  3-21
