Rebuild dense nurbs mesh to lighter one after importing it as obj/subd (script)
 1-14  15-24
8622.15
Hi James,
I can not get a result having followed your instructions.
The node loads ok and runs but no result so not sure if
I'm missing something.
Any thoughts?
Barry
8622.16 In reply to 8622.15
Hi Barry
Try the attached, ensuring that "pretopologize.3dm" is opened prior to loading "retopologize3.nod"
"SelectByName" will auto load surface for re-topologizing.
EDITED: 14 May 2019 by JFH
8622.17 In reply to 8622.16
Hi James,
found the problem when I opened the retopologize macro the IsoCrvs & mPathArray node are in red meaning I don't have them.
So can you post them or point to where they are on the forum please.
Barry
8622.18 In reply to 8622.17
Hi Barry,
Replace nodes/extensions folder with one from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
It would be prudent to make a copy of existing extensions folder
just in case you need to reinstate it.
8622.19 In reply to 8622.18
Hi James,
sorry still no luck getting the following error message.
Barry
Size: 151.2 KB, Downloaded: 57 times, Dimensions: 600x562px
8622.20 In reply to 8622.19
Hi Barry.
I'm running "retopologize" nodes with LATEST 0.97 version of NE and all works fine.
You are running 0.96
Maybe that is the problem.
Marco (mdkm)
Message 8622.21 deleted 14 May 2019 by JFH
8622.22 In reply to 8622.19
Hello Barry,
it Looks like you don't have basicFunctions.js in extensions\libs Folder.
The additional nodes should work since V0.85 up to now.
Have a nice day
Karsten
8622.23
thank you all for your answers it's working fine as Karsten said I was missing the basicFunctions.js
Cheers James it's going to be a useful node.
Barry
8622.24 In reply to 8622.4
@mkdm:
Does that method work on full three dimensional objects or only on planes?
May I change mesh in your way (like on your video tutorial) on model like that:
Show messages:  1-14  15-24
