| Hi Brian, by the way the Draw curves > Circles > Tangent command can generate a circle tangent to 3 other curves currently.
 > but the question is, can the center of a circle be found like the following var x1 = code which does not work:
 Sorry no, currently there isn't anything set up for returning circle properties to script, the only things exposed specific to curves currently are:
 crv.isClosed   property,
 crv.getFacesOfEdge()
 crv.getUVCurvesOfEdge()
 crv.getStartPt()
 crv.getEndPt()
 crv.getLength()
 > Second question, is the c1.radius code OK?
 I don't think so - I'd think it is returning "undefined".
 > Third question, is a circle just another curve, or is there objectpicker
 > code to restrict selection to circles?
 Sorry no there isn't currently, the current ones are just by more general object type than that:
 allowCurves();
 allowStandaloneCurves();
 allowEdgeCurves();
 allowFaces();
 allowBReps();
 allowPointObjects();
 allowEditPoints();
 allowTopLevelObjects();
 Probably a good way to add a more flexible one would be to let you pass in a function that the objectpicker would then call to decide if an object should be allowed to be picked or not.
 Those are some things that I can add in for you in v4 once it's underway. Not too much longer...
