Scale object while in Orient Tool
All  1-3  4-5
8607.4 In reply to 8607.1
Hi klauio, I'm sorry no there isn't any way currently to do scaling built into the orient command. That's because the inputs used for orient aren't automatically also suitable for scaling without having to do extra steps.
You can do scaling in the line to line version of orient because the way it works has 2 lengths that can be used for the scale.
8607.5 In reply to 8607.4
Hi Michael!
Thanks for the info and explanation. It's not that huge of a problem since currently i am using Scale Tool instead so it's not a dead end and i just
need to readjust workflow a bit. Line/Line is cool but somehow for this particular thing i just like Scale or Scale 1D.
It would be cool if possible for Orient to have something like scale mode too. Maybe kind of a similar like you can rotate where at first the object
aligns to base object as you drag on it but then when you click and choose one of the axis you can rotate the object. In a similar way
you could enter scale mode with those axis selected while still in Orient tool so you can scale object then go back and still drag object to align it
to base. > Suggestion for Moi v4.0 or later, if possible. ;)
Show messages: All  1-3  4-5
