MASTER MODELLERS Modelling Approach
All  1-2  3-13
8587.3
Thanks for link will delve into it here is link to artists site.
http://www.bridgesmathart.org/art-exhibits/jmm09/friedman.html
8587.4 In reply to 8587.3
There are 3+ views of the carved 10" X 6" limestone, of carved wood here:
http://breezyhillturning.com/Minimal-surfaces/minimal-surface-turnings.html
Copy of paper by professor Nat Friedman:
http://math.unipa.it/~grim/21_project/21_charlotte_FriedmanPaperEdit.pdf
Note that the soap film, figure 3d, has two holes with two surfaces, and the same trefoil knot is shown in figure 7c,
as a two hole knot, which is formed by manipulating the one hole, one surface, trefoil knot of figure 7a.
I have not found a surface evolver model yet.
8587.5 In reply to 8587.4
There is a tinfoil model of the knot here, as well as 1/4" copper wire.
http://t.archive.bridgesmathart.org/1998/bridges1998-139.pdf
So making such a trefoil knot in wire, and dipping it in soap and glycerin, popping the two holes,
should give a physical model...
Surface evolver is the other option...
EDITED: 14 Sep 2017 by BEMFARMER
8587.6 In reply to 8587.5
The program for surface evolver, for a different sculpture, between an unknot and a trefoil, is explained here:
https://www.thingiverse.com/thing:1559227
Looks like a mirrored version of Jotero's Yin Yang. :-)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5529.1
8587.8 In reply to 8587.7
Hi Stefan!
Wanderful model! Could you post the 3dm ?
Thanks.
8587.9 In reply to 8587.8
Sorry Marco, better not...
Best regards
8587.10 In reply to 8587.9
OK. No problem.
Bye.
That is the one I half remembered, only 5 years ago!
Time to try again...
As far as I know, there is not a .3dm available.
The front view and the left view are symmetrical.
8587.12
Hi All,
Thanks for the leads cant believe the historical trail needles in a haystack falling in the same pile - MOI a great forum with a diverse range talents!
Will digest posts contained.
Best regards
8587.13 In reply to 8587.12
IMHO, the "yin-yang" is a seifert minimal surface on a trefoil knot.
Using the flat crossing knot diagram of the trefoil knot, showing two holes, the "braid" type,
there is a procedure to make a seifert surface by replacing the crossings by bands rotated 90 degrees.
Unrotating the central band orients the two holes to 90 degrees, and the flat surface becomes 3D.
Show messages: All  1-2  3-13
