Surface Stress Map
All  1  2-6
8544.2 In reply to 8544.1
Hi Ivan, it's hard to answer without seeing an example. Do you have a file that has one of these complicated compound curvature surfaces so I can get a better idea?
8544.3 In reply to 8544.1
Hi Ivan,
There probably wont be a way to do it on a "Surface". but there is a command written that will do it on "curves". (Attached zip. I don't remember who wrote it for credit. It wasn't me.)
So you could use this with extracting isocurves and running a curvature analysis on them.
There is an original one that doesn't add the "points" to the result, if you want that one instead.
8544.4 In reply to 8544.3
(Karsten's CCC script)
8544.5 In reply to 8544.4
Thanks bem... and thanks again karsten!
8544.6
thanky you guys and MG will have a look
Show messages: All  1  2-6
