Lofting Enigma
All  1-4  5-9
8528.5 In reply to 8528.4
Yes, teh goal is to shell after.
So in general it is not possible to loft curves which are twisted around 180 degrees ?
8528.6 In reply to 8528.5
Hi Tom,
Sorry no that's not possible to do in a single loft - a closed loft and just closed surfaces in general cannot have a closing seam where the start and end are flipped from each other. You will need to make a model like that out of more than one surface instead of just one single surface.
Well, not like you want to have it, IMHO.
I also don't understand why you not use method one, i suggested, because it gives a better result
than solution two. Only problem might be filleting afterwards.
8528.8 In reply to 8528.7
>>I also don't understand why you not use method one<<
Stefan, thank you zhat you insisted. When I first applied Blend to fill the
gap, the curvature of the gap was not blending completely smoothely with
the open ends. Thats why I posted my question looking out for creating
the entire loft as one. I had a look again and the filled gap seems to blend
perfectly now !
Hi Tom,
glad that it works now for you!
Show messages: All  1-4  5-9
