Moi To Modo/ Export questions
All  1-3  4-11
8527.4 In reply to 8527.3
Thank you for the reply. I will read over that thread.
Yeah I don't edit any geometry after I export. But a lot of times the geo was coming in with faceted N gons. To fix this sometimes you can select the faulty polygon and bevel it in 1mm and it would flatten it, but a lot of times this wouldn't work and the facets would show up in the render. I heard there are new export options in v3 in the preferences for modo. Just wondering if that fixed this problem.
Thanks again.
8527.5 In reply to 8527.2
Sorry coi I didn't see your post when I replied. (New to how these forums work :/) I have tried quads and tri's as well. Still facets. I need to use like an angle of at most 5, for the detail I need for my clients.
Like I said, I am on Version 2, so hopefully I can get version 3 and see if that does the trick. But overall OBJ has been pretty good instead of LWO. But would just love to have LWO work nicer.
8527.6 In reply to 8527.5
Hi kallas08,
Could you eventually post a piece of the model (.3dm) to get a better idea of the problem ?
Are you using a bump map texture in Modo ?, or is the faceted look happens without any 'fancy' material on it ?
8527.7 In reply to 8527.5
Hi kallas08,
not to worry. You might just grab the Moi V3 30-day trial over at the download section and give it a spin.
http://moi3d.com/download.htm
8527.8
Yeah I will try out that trial. Thanks for that!
I will do some testing with the trial first. Then I will post a part if I can't get it resolved. But it is when I have a highlight hitting the surface basically. Like lets say I put a mirror surface on it, there will be a sharp edge like breaking up the reflection and distorting it. I will give this trial a go and report back.
On a side note, I am really surprised with this community so far. Seems like you guys are great and the response time is top notch.
Thanks everyone!
8527.9
Damn, I must have used the free trial for version 2 a long time ago, now I can't for version 3. Is this possible to start over? If this fixes my problem, I will upgrade for sure...
Thanks!
8527.10 In reply to 8527.9
hi kallas08,
can't really help you with the trial issue, but you can always post those parts as 3dm files, so we can have a look at them or/and provide you with some test exports
best
8527.11 In reply to 8527.9
Hi kallas08, please e-mail me at moi@moi3d.com and I can set up a new v3 trial for you.
Show messages: All  1-3  4-11
