WIP section. All about personal works, renderings, WIPs
 1-8  9-28  29-36
Hi all,
a little test with my Stanford bunny quad mesh, imported into MoI and then i used Max's subd script
to smooth the mesh.
After that i separated the NURBS patches and saved as .obj again to auto colorize the individual parts
and did an additional toon render pass, to obtain the wireframe look, in Shade3D.
EDITED: 14 Aug 2017 by STEFAN
8525.30 In reply to 8525.29
Hi STEFAN.
Cool render.
It's an interesting topic : http://graphics.stanford.edu/data/3Dscanrep/
Bye.
Thanks Marco.
Yes, the Stanford repository is well known and the models there are very often used
in scentific works.
Hi everyone!
Little quick and dirt render while learning InstantLight.
Workflow : Moi (for the base concept), 3D-Coat (voxelization, retopo, painting), InstantLight (GI realtime rendering)
All effects (bloom, noise, dirty, GI, shadows, LUT...) are in realtime.
This is the low-res rendering :
Here's the 4K version : http://take.ms/Sf7tR
Here's the starting base concept in Moi :
Bye!
Marco (mkdm)
Hi everyone!
I had some fun with the topic posted by @AndrewG at http://moi3d.com/forum/index.php?webtag=MOI&msg=8554.1
So I made some modelling test based also on an idea taken from @BurrMan (http://moi3d.com/forum/index.php?webtag=MOI&msg=8554.14)
and I created my very personal interpretation.
Here's the 3dm file : https://monosnap.com/file/pvrsQIISEbsC3JGGVXbyhQcsNt1Ado
(All objects are perfect solids inside Moi.)
Here are some Moi's screen shots :
And here's the 3DCoat quick render :
(full size : https://monosnap.com/file/VrAzEmY8H2caymDjleSmNCj13hMc5H)
Bye!
Hi everyone!
Going further into practicing with the superfast workflow : Moi -> 3D-Coat
This is my latest concept : "Metal ET Plant"
Here's the 3dm file : http://take.ms/o3UQO
Here's the Moi's screen capture :
Here's the 3D-Coat quick render. Full scene is about 22 Mil polygons in voxel mode.
NO UV NO RETOPO, ONLY VERTEX SHADERS.
Here's the hires version :
https://monosnap.com/file/uhk8QbHJaW0wetNPjMZdfmVFZY0SIz.png
From scratch to finish, including final composition in Affinity Photo, about 3 hours.
Bye!
8525.35 In reply to 8525.34
P.S. As you can see the perspective is exaggerated with a great FOV value inside 3DCoat.
Hi everyone!
Taking inspiration from this thread of AlexPolo (http://moi3d.com/forum/index.php?webtag=MOI&msg=8587.1) I have created these objects in Moi.
The starting model was a simple extruded disc with two circular holes.
I have modified the starting model in several ways.
Final renderings in 3D-Coat with Vertex Shader.
This is the 3dm file : http://take.ms/aU3jI
and these are the rendered objects :
Bye!
Show messages:  1-8  9-28  29-36
