WIP section. All about personal works, renderings, WIPs
 1  2-21  22-36
Hi Marco,
here is a doodle i made of 55 spheres with MoI. But please don't ask how i made this, because i did
the base NURBS model some years ago and forgot the name of the Software which helped me to do
this with MoI.
Hope you like.
https://www.behance.net/gallery/55030111/Stanford-Bunny-Experiment
8525.3 In reply to 8525.2
Hi STEFAN!
Cool!
Simple but cool. Psychedelic rabbit!
Thanks Marco.
Hi Everyone.
Little quick and dirty 3d doodle made using this FxGraph function posted by @bemfarmer (http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.33)
Just less than 5 minutes to model one single piece in Moi, export, apply shader and rendered inside 3D-Coat bult-in renderer.
Bye.
Marco (mkdm)
P.s. A little variation.....(Moi + 3D-Coat + Affinity Photo)
Bye.
Nice Marco,
did you rounded the edges with 3DCoat, or are they MoI fillets?
8525.8 In reply to 8525.7
Hi STEFAN.
@You : "...did you rounded the edges with 3DCoat, or are they MoI fillets?..."
Oh no.
This time I had only some free minutes and really not time to try the more complex method.
But in this case I had no problem to perform filleting directly in Moi, so no need to try alternative ways.
Anyway, I've also did a fast test with the 3D-Coat voxel method.
1) Without retopology (1.5M polygons)
The video capture : https://monosnap.com/file/SnOlPzTYZvMPlMnF9sfUAZRVu8JDgp
Thee screen capture :
2) After default retopology (86K polygons)
The video capture : https://monosnap.com/file/6ID8FX2P77F3uyZ9PGuiDMp0hi9oon
Bye.
Hi Marco,
thanks for the info!
Hi everyone!
I made this little 3d doodle based on Max's FXGraph3D script and Moebius example by Mike (MGG942) (original post http://moi3d.com/forum/index.php?webtag=MOI&msg=8534.1)
Workflow : Moi -> 3D-Coat (Voxel, round edges, UV, Texturing) -> Blender (setup scene and cycles render), Affinity Photo (post process)
Made in about two hours just for fun. As you can see there are some voxelization artifacts in the center of the model.
The 3dm file : https://monosnap.com/file/5vUf2aenq93RJe8rLhQliED9NkoFnr
Moi's screenshot :
The final work.
Bye.
Marco (mkdm)
EDITED: 30 Jul 2017 by MKDM
8525.11 In reply to 8525.10
Great work ! Love that rusty texture created in 3Dcoat.
8525.12 In reply to 8525.11
Hi SIRTOM.
Thanks!
8525.13
Nice.
Hi everyone.
Just a little break during daily (rather tedious) Android developing job...
How funny can be Twist results even with a very simple object...
Workflow : Moi3D -> 3DCoat (Painted directly in Paint Room over hi-poly without retopo and UV) -> Affinity Photo
The 3dm file : http://take.ms/0mjn8
The screen Moi's capture :
The final results retouched in Affinity Photo :
Bye!
8525.15
Hi this is my latest project. Everything was modeled in Moi3d, render in Blender.
Can't upload all of them so here is the link: https://www.artstation.com/artwork/l4aWG
Hope you like this !
Size: 607 KB, Downloaded: 61 times, Dimensions: 1119x1080px
Size: 1.8 MB, Downloaded: 55 times, Dimensions: 1920x1485px
Size: 1.3 MB, Downloaded: 45 times, Dimensions: 1920x1399px
Size: 960.2 KB, Downloaded: 53 times, Dimensions: 1920x1080px
8525.16 In reply to 8525.15
Hi Tam!
Very cool and interesting.
If I can say a word, I find your renderings a little bit underexposed.
Maybe a little bit more global illumination could give better results.
Only a personal opinion.
8525.17 In reply to 8525.16
Thank Marco.
I will check that again. Still playing with Cycles these days. Need to make more control on those thing.
Thanks again man !
8525.18 In reply to 8525.17
Hi Tam. You're welcome!
Have a nice day
Cycle is cool but this one seems also cool! :)
Message 8525.20 deleted 5 Aug 2017 by MKDM
Hi everyone.
**EDITED POST**
I've spent a couple of hours to find a way to produce very fast, quick and dirty 3d concept art rendering using my current software pipeline.
Actually my aim is to get rid of the whole tedious and so time consuming task of Retopo, UV, Texturing, Export all stuff to external renderer.
All this extra work for me is totally a waste of time when I only want to produce quick renderings of concept models as fast as possible.
In this stage I'm not looking for photorealistic results.
So, after spending some time and searched here and there on forums, especially on 3D-Coat's forum, I have found a workflow that could give me great results
considering all I have said before.
The workflow involves 3D-Coat Vertex painting with PBR shaders.
In this way I can apply shaders directly into the sculpt room over very High-Poly mesh voxels and perform texturing with Smart Materials in Paint Room,
without the need to do Retopo and UV.
For this my very first experiment I have used this workflow :
1) Moi + Rocket3F for creating the base mid-poly mesh
2) Import into 3D-Coat and voxelize the mesh to get a High-Poly mesh
3) 3D-Coat PBR Shaders and Smart materials directly over High-Poly mesh
4) Performing a quick render with 3D-Coat's built in renderer
I will continue to investigate this workflow and also with the alternative PTEX workflow inside 3D-Coat.
This final scene in 3DCoat is 47 Mil polygons.
I made the final composition with Affinity Photo.
Bye!
Show messages:  1  2-21  22-36
