SIMPLE BOOLEAN PROBLEM
All  1  2-6
Message 8517.2 deleted 16 Jul 2017 by MKDM
8517.3 In reply to 8517.1
Hi AlexPolo.
You are referring to the Green objects ?
Have you tried to select all Green objects and perform a "intersect" command to try to see what's going on ?
8517.4 In reply to 8517.1
Hi Alex, your boolean succeeds over here, does it work for you if you reload the file?
When many objects meet at a single crown point like that it needs some special handling in the intersection process, it's a pretty complex thing not really what I'd call a simple case.
8517.5
Hi - I copied items into new screen and BOOLEAN aok - not sure why in parent model not working
thanks again.
8517.6 In reply to 8517.5
Hi Alex, well it's probably a bug of some sort, but it's very difficult to figure out what went wrong when it's not repeatable.
Show messages: All  1  2-6
