How to get rid of all filleting issues if you don't need a REAL fillet
 1-9  10-29  30-49  50-58
In fact fact seems there is in ZBrush a very easy method! :)
enable Render / Properties/ Smooth Normals (so nothing to do! Except some subdivisions if you want...but not obliged)
and you have even possibility of an slider ehancement factor 1 to 5
Model by Mdkm directly from export Moi.OBJ
Factor minimum 1
Factor maximum 5
EDITED: 23 Jul 2017 by PILOU
8512.51 In reply to 8512.50
Edge Erosion V2
EDITED: 18 Jul 2024 by PAQ
8512.52 In reply to 8512.51
Obsolescence programmée! :)
Looking great PaQ!
8512.54 In reply to 8512.51
Hi PaQ.
Wonderful setup and scene!
Unfortunately I haven't had free time to explore Houdini with your "round edge" example setup.
I hope soon to make a personal test.
As I said, above all I'm interested in testing what will be the degree of difficulty in UVing the resulting obj file.
So I'm looking for a solution to achieve the best compromise between polycount, edge loops and quality of round edges.
I will let you know.
If I will need some extra tips to achieve these goals using Houdini, for sure I will ask your help :)
See you.
8512.55
Hello,
A bit off topic, but while working on my edge erosion prototype, I manage to find a way to extract those nice surface curves from MoI model.
The cool thing is that you can then render them in any software (here it's Modo801), as they are just a poly mesh.
(I might put together a small tutorial about this, depending of the interest).
Hi PaQ,
looking very nice. Please let us know. I did in the past extracted edges by copy and paste
and then saved as polyline in .dxf format. But this worked then only in my DCC app
in wireframe rendering mode :-(.
8512.57 In reply to 8512.55
Hi PaQ.
Thanks a lot for this very interesting off-topic.
But...@You : "..as they are just a poly mesh...."
What do you mean ?
I know that if I extract nurbs edges in Moi I get just....curves. Not mesh.
What am I missing ?
Thanks.
Marco (mkdm)
EDITED: 24 Jul 2017 by MKDM
An interesting read for a new Bevel Shader.
https://developer.blender.org/D2803
Show messages:  1-9  10-29  30-49  50-58
