Making seams / grooves on curved and flat sci-fi surfaces - how ?
All  1  2-7
8511.2 In reply to 8511.1
Hi motorsep.
You can watch this very interesting tutorial by Chipp Walters : https://youtu.be/jQl-0waABAM
Another technique can be use a mix of Isocurve + Sweep with circular or rectangular shapes + boolean difference.
If I find some free time I'll make a simple tutorial about that.
Bye.
8511.3 In reply to 8511.1
P.s also check this video from 4:37 : https://youtu.be/X5r3xc_Go3o
8511.4
Thanks Marco!
Message 8511.5 deleted 8 Aug 2017 by OVERTHERE
Message 8511.6 deleted 8 Aug 2017 by OVERTHERE
8511.7
Hi Motosep I've tried to show what Mkdm was describing in the attached images.
1) Start with a curve on the geometry of interest, make sure it has curved corners to some extent as sharp changes lead to artefacts. A simple way to do this is to use the Curve - > project function to transfer a rounded rectangle onto the geometry
2) Draw a small curved shape such as a circle or rounded rectangle (again sharp edges lead to artefacts), see bottom of picture, and use Sweep function to generate temporary geometry. I've exaggerated size in example image to make easier to see.
3)Subtract temporary geometry from main object to generate cut line using Boolean -> Diff function and you have your cut line.
The final two images show a finer size of cut line generated using a smaller rounded rectangle for the sweep in moi and rendered out as an example of the effect
Andy
Size: 142.7 KB, Downloaded: 34 times, Dimensions: 1196x807px
Size: 187.8 KB, Downloaded: 46 times, Dimensions: 1072x816px
Size: 202.9 KB, Downloaded: 43 times, Dimensions: 1248x931px
Size: 118 KB, Downloaded: 43 times, Dimensions: 1457x855px
Size: 487.8 KB, Downloaded: 44 times, Dimensions: 735x464px
Show messages: All  1  2-7
