Is there a way to "inverse" something in the function "Blend" when you obtain A against B?
For obtain B after result A, I must inverse side "A" or rotate the right rectangle A :)
(all rectangles are "solid plane" )
or maybe inverse the order of the clics ? :)
Seems works :)
Is that normal?
Oops, your graphic there is not quite right - you don't want to click near the middles, you want to click closer to one end than in the middle, but it needs to be on the same ends that you want to have matching.
So I will add your text to the drawing :)
Done, and sorry for this little misunderstand but it was a little confused for me :)
In any case a very strong function!
