Problems with new machine
All  1-2  3-5
8497.3 In reply to 8497.1
Hi Shane, my guess is that it's a permissions problem that's preventing MoI from writing to the moi.ini file. It's probably that your old user account has ownership of the directory and the files and you need to take ownership of those on your new machine.
Try something like this on both the Application Support/Moi folder and the files in the folder too: http://osxdaily.com/2013/04/23/change-file-ownership-mac-os-x/
8497.4 In reply to 8497.1
Hi Shane I would suggest you make sure that everything from your old App Support Moi folder be copied to the new machine App Support Moi folder. Also you should also copy all the Moi related preferences from the old Machine to the New App Support/Preferences folder, reboot and launch Moi. Hope this helps.
8497.5
Thanks for the help guys. It was related to permissions but none of the suggestions worked. I ended up deleting everything and re-installing form scratch. Then I just opened up the new .ini and pasted my old .ini info in and saved. Then I manually copied over the scripts etc from my old installation.
-Shane
rendering . animation . oddlyeven.com
Show messages: All  1-2  3-5
