Trouble opening pipe
All  1-6  7-15
8492.7 In reply to 8492.6
Still, is there a test, other than zooming in, to tell whether a point is on a surface, instead of just really, really close? If not, how do I know I'm zoomed in enough during inspection?
E.g., as far as I can tell, the end of the curve in this attachment is on the surface, but I still can't open the end of the tube on that surface (I've left it un-unioned to make it easier to inspect).
EDITED: 25 Jun 2017 by INVOLUTE
8492.8 In reply to 8492.7
Hi Involute,
Not really - well I guess if things seem to be behaving oddly that's a sign to do a closer inspection.
I go in something like 6 or 7 pushes of the mouse wheel. You don't want to go in too extreme because when things are only say 0.0000001 units apart that's totally ok. It's when things are more than 0.001 units apart that they're going to be considered separate pieces and won't intersect with each other.
That's actually normal - union doesn't really open holes in things, it combines things together and only removes pieces that are contained inside both objects. So the part that you want to have as a hole isn't contained inside the hollow tube you have, it's only in the main body volume so that part will be kept.
For drilling a hole you want boolean difference for that instead of boolean union. If you want the inner tube to be totally open all the way through you want to have 2 separate tube objects an outer and an inner one - first do a boolean union with the outer tube and your main object, then follow that by a boolean difference using the inner tube as the cutting object.
Here's a simplified example - if you have this tube solid and this sphere solid:
When you union them, it gives a result like this:
They are combined into one object now but there's no hole through the sphere, basically when you union 2 solids together the result is going to look from the outside the same as before, the only stuff that's been removed is all the extra inner structures.
Hope that makes sense! I can understand how it seems like the hole in a hollow tube is part of the object and so you're expecting it to persist during a union, but the way it works is when you have a hollow tube, it's only the thick wall that is really part of the solid, the hole in the middle is empty space same as empty space all on the outside of everything...
8492.9 In reply to 8492.8
Jeez, that was so easy. I was differencing the tubes (to make a single hollow tube) and then unioning the result to the model, then deleting the surfaces that intersected the tube, which caused all kinds of problems, and I still couldn't get an opening in the inclined plane. Anyway, unioning the outer tube with the model and and then differencing the inner tube accomplished exactly what I wanted. I'm still learning to think like MoI, I guess. Thanks a lot.
8492.10
Hello Involute,
Have you considered running the pipe parallel to the long plane so you can blend the connection out at the bottom at a less acute angle?
8492.11 In reply to 8492.10
Thanks for the tip. At one point I thought I was going to have to put a sensor on the tube where it passes through the horizontal plate and wanted to preserve some space between the tube and inclined plane to accommodate it. Now I don't think I need it, but since I got the geometry to work as is I'm not going to mess with it. ;-)
8492.12 In reply to 8492.11
The Pipe2 command is here.
http://kyticka.webzdarma.cz/3d/moi/#Pipe
8492.13 In reply to 8492.12
Thanks, I found it. Slick tool!
8492.14
Hello,
A technique that gets you within the bounds of your cylinder and may be less restrictive on flow. I can't post the file because I'm out of space on the forum, but I could do a video if that would be helpful.
Pipe
EDITED: 2 Feb 2025 by OSTEXO
8492.15 In reply to 8492.14
Thanks for working on this, OSTexo. Aside from the fillets (which I just added; thanks for the idea), I'm not sure what you're doing. I won't impose by asking for a video. I have what I believe is a working solution for now. I don't think the flow will be a problem (the tube just has to pass a single M&M candy every few seconds). If it becomes one, I'll come back here and revisit.
Show messages: All  1-6  7-15
