Trouble opening pipe
All  1-9  10-15
8492.10
Hello Involute,
Have you considered running the pipe parallel to the long plane so you can blend the connection out at the bottom at a less acute angle?
8492.11 In reply to 8492.10
Thanks for the tip. At one point I thought I was going to have to put a sensor on the tube where it passes through the horizontal plate and wanted to preserve some space between the tube and inclined plane to accommodate it. Now I don't think I need it, but since I got the geometry to work as is I'm not going to mess with it. ;-)
8492.12 In reply to 8492.11
The Pipe2 command is here.
http://kyticka.webzdarma.cz/3d/moi/#Pipe
8492.13 In reply to 8492.12
Thanks, I found it. Slick tool!
8492.14
Hello,
A technique that gets you within the bounds of your cylinder and may be less restrictive on flow. I can't post the file because I'm out of space on the forum, but I could do a video if that would be helpful.
Pipe
EDITED: 2 Feb 2025 by OSTEXO
8492.15 In reply to 8492.14
Thanks for working on this, OSTexo. Aside from the fillets (which I just added; thanks for the idea), I'm not sure what you're doing. I won't impose by asking for a video. I have what I believe is a working solution for now. I don't think the flow will be a problem (the tube just has to pass a single M&M candy every few seconds). If it becomes one, I'll come back here and revisit.
Show messages: All  1-9  10-15
