CSec Profiles, as in Rhino
All  1-4  5-14
849.5 In reply to 849.3
Hi Jess, do you possibly have a model file of the spoon shape curves? If you could attach it here that would help me follow your description.
> Maybe for version 2? (Here's dreaming)
Yeah, version 1 is pretty much wrapped up at this point, I'm pretty much just tweaking it with bug fixes for the moment.
But CSec is actually not very technically difficult, it's really just a packaged up version of InterpCrv. Once I get started on version 2.0 it should be pretty easy for me to add a few more scripting methods and then make a plug-in that would do it for you.
Until then copy/paste to Rhino for this one is your best bet, although you can do a "manual" CSec in MoI by drawing in some lines, select the long segments and then hit Edit / Trim, use the lines as cutting objects, then hit "Done" to leave all the pieces (the long guides will now be sliced up into smaller segments). Then you can use Draw curve / Freeform / Through points and snap on to the endpoints of those segments to get your CSec type profiles. That should work in a pinch (let me know if you want more detailed steps for this), but probably copy/paste to Rhino is faster for this one.
849.6 In reply to 849.4
Hi Jess,
> Is there a way one can do something similar, or am I just fishing.
Well, you can edit these long sections in a similar way, add points in that area and adjust them to tweak the shape... It is kind of a 90 degree shift in thinking though.
One benefit of this method is that you might be able to use a fewer number of curves to define the shape, which can be good. One problem with lofting with many sections is that it tends to create stair-steppy kind of wiggles if you try to get the surface forced through too many sections.
849.7 In reply to 849.6
Using extra longitudinal profiles works perfectly for now, A little more work than the Csec's but a simpler than the slicing and dicing. Thanks for the pointers... (C joke)
V2 with Csec, and hopefully the dreamed about layers ..(ref: other user requests), will make me pack away most other nurbs toys, and go MoI culting on the highways.
And a great thanks for making MoI nurbs my 3d pencil with an amazingly simple approach to CADding. My hat off to you sir.
Jess
849.8 In reply to 849.7
Thanks Jess!
Actually I was just thinking that there may be possibly enough stuff in place already to add in a custom CSec command right now, I'll give it a try tomorrow to see if I can put it together with the existing scriptable stuff.
849.9 In reply to 849.7
Ok Jess, good news for you - there was indeed enough scripting stuff hooked up already to make a CSec command for the current version, I've attached the new command to this message.
Here's how to use it.
First download and unzip the attached CSec.zip, copy the the 2 files (CSec.htm and CSec.js) to the \commands subfolder under your MoI main program files folder. This is the default install location:
c:\Program Files\MoI beta Aug-1-2007\commands .
That installs the new CSec command, but you need a way to trigger it - you can do this by adding a new keyboard shortcut under Options. Put in whatever key you want (like for example "C"), and put in CSec for the command.
Now you can select your CSec curves in order, and then push C, to do your CSec-ing right inside of MoI.
Here's a visual overview for others who aren't familiar with CSec. Given a set of scaffolding curves like this:
You can then pick these 4 curves (one by one in order from first to last in a circular order), then run CSec to generate a curve that interpolates a planar slice through the scaffolding. So you pick lines like this:
Which become cutting planes and each line generates a new cross-section curve. You repeat this with many lines and you get a bunch of cross-sections like this:
You can then loft through these or use them for whatever...
849.10 In reply to 849.9
Wow Michael, it's just amazing how you just whip up all this power so easily in MOI!
I can't wait to read an article about you in Computer Graphics World!
-Will
849.11 In reply to 849.10
Thanks Will! One thing that helps is that MoI uses scripting heavily in its normal operation for every command. What I mean is that the scripting is not just something that is bolted on extra, it is deeply embedded and used for basic operations in MoI.
So you can do pretty sophisticated stuff with scripts, create UI that is the same as any regular MoI command, etc... The only tricky part is that it will take me quite a bit of time to document it (and write scripting tutorials, etc...) so that others can use it to do these kinds of extensions more easily. I won't be able to focus on that kind of scripting documentation for a while yet.
In this case this new command basically combines together elements of several different commands - Line, Extrude, Intersect, and Curve through points.
There are a still a few things to streamline for scripting, but I'm really happy with the overall scripting architecture, it gives me a lot of flexibility when building new commands.
849.12
I have a problem with the CSec script. Here I am attaching the 3dm file. If I detach a little the profiles, then it works, but that's not what I need..
Thank you.
849.13 In reply to 849.12
Hi wastzzz, yeah it's related to how the csec script calculates intersections between things - if the csec rails also intersect with one another it generates another intersection point and messes up the script.
You can still easily get what you need by using detached profiles - start with your profiles how you want them with them all touching at the ends. Select them and do a Ctrl+C to copy them to the clipboard.
Now draw in 2 lines in the side views near the ends, use Edit > Trim to cut the ends off and now you can use Csec on those cut rails that do not touch at the ends. When you are doing doing csec delete the cut up rails and do Ctrl+V to paste back in the original uncut rails and you should then have the result you want.
849.14 In reply to 849.13
Understood, thank you for the workaround, it's working :)
Show messages: All  1-4  5-14
