Thanks Will! One thing that helps is that MoI uses scripting heavily in its normal operation for every command. What I mean is that the scripting is not just something that is bolted on extra, it is deeply embedded and used for basic operations in MoI.
So you can do pretty sophisticated stuff with scripts, create UI that is the same as any regular MoI command, etc... The only tricky part is that it will take me quite a bit of time to document it (and write scripting tutorials, etc...) so that others can use it to do these kinds of extensions more easily. I won't be able to focus on that kind of scripting documentation for a while yet.
In this case this new command basically combines together elements of several different commands - Line, Extrude, Intersect, and Curve through points.
There are a still a few things to streamline for scripting, but I'm really happy with the overall scripting architecture, it gives me a lot of flexibility when building new commands.
