OBJ Problems with my current 3DM File
8487.1
Hey, hello dear moi3d users - I'm spend the last months on focus on digital painting and now I did made a simple model in 3D, with moi3D - its just a simple tower for my next painting. For a Painting my result is nice ebough, but I see in SILO, that my OBJ Mesh (exported form moi3d) - did have some weird extra polygons - at the same place, like an onion with a second skin. How can I avoid an ONION-EFFECT?
here is my file-location
http://www.mediafire.com/file/zuf3fu7yezhpz9o/darktower-2export.3dm
thank you so much
8487.2 In reply to 8487.1
DANGER, trying to download this brought up some virus-like verbal and visual warning on the screen, about "infection".
(Call this number or else...)
Task manager was used to finally kill the annoyance.
The file would not download.
8487.3 In reply to 8487.1
I don't see it - but i had a curious thing : export as obj, then export again as obj saturates my memory!
it's the dark tower of Stefan King ?
EDITED: 21 Jun 2017 by PILOU
Hi Lordfox,
i exported your model from MoI as NGons and it shows up in Silo 2.3.1 properly.
I can see no artifacts.
8487.5 In reply to 8487.4
Hi
It imports ok as an obj to simlab. Exported as quads and tri's.
Keith
8487.6 In reply to 8487.1
Hi Lordfox, some programs can get confused with handling complex n-gons (polygons with more than 4 sides). Usually that looks kind of like you're describing with triangles leaking outside the shape.
If you run into that you should try using the "Export: Quads & Triangles" option at export time from MoI, that will triangulate any n-gons in MoI instead of the triangulation happening in the other app.
- MIchael
8487.7 In reply to 8487.6
ok, thank you for you answers, so I will try to use better tri-angles and quads.
Yes @Pilou, I did build this tower for my Overpainting 'Dark Tower' Illustration ;)
8487.8 In reply to 8487.7
@LordFox : personnaly I must finish this dark Tower serial! I am stopped at "Les loups de la Calla" (Wolves of the Calla) ;)
Hi lordfox,
it is strange that you had this problem, when importing into Silo.
Did you used the latest version of Silo and MoI?
