Fillet trouble
All  1-4  5-8
8482.5 In reply to 8482.4
Hi Involute, I tested it with a fillet of 0.05 units and it's working fine for me over here, 3DM file is attached. You do have to make sure to select the entire sequence of edges though, there are also 3 edges in these areas:
0.05 is about all that will fit, much larger and it will run out of room here:
8482.6 In reply to 8482.4
Hi Involute, I don't know if this is important or not but also note that the fillet will eat away some material underneath the other solid disk shape here:
8482.7 In reply to 8482.5
Aah, I didn't realize I had to select all the edges. Works for me now, too. Thanks.
8482.8 In reply to 8482.6
Thanks for pointing that out. Fortunately it won't matter in my application.
Show messages: All  1-4  5-8
