Shortcuts get lost
All  1  2-4
8477.2 In reply to 8477.1
Hi agonyii, it's probably the multiple open sessions - MoI will write the current instance's settings out to the moi.ini file when MoI exits. But if you have 2 instances open and your new shortcut is set up on one of them, if you exit the instance that doesn't have the new shortcuts set in it last, your shortcuts can get overwritten.
So when you're setting up a new shortcut, exit any other running instances first, and exit that instance of MoI before starting any others.
I've tried to think of a good way to avoid that from happening by making all running instances change when you modify a setting, but it's a rather complex thing to set up.
8477.3
that's the first thing I though myself but I don't think it is. As I said, I did some tests prior. I have configured and closed Moi to start fresh if I was going to use multiple sessions. It works fine most of the time but after some longer period looks like .ini still gets corrupted. I did not setup any new shortcut. I guess that's quite possible considering Moi is at least doing reordering of shortcuts by 'ABC' when the app gets closed.
I appreciate the help in any case!
EDITED: 18 Jun 2017 by AGONYII
8477.4 In reply to 8477.3
Hi agonyii, is it possible you have any restrictive permissions set on the folder where MoI is trying to write moi.ini to? Or maybe a virus checker might be doing something?
MoI stores shortcuts in memory in alphabetical order, so that's how they'll get written out at exit time.
Show messages: All  1  2-4
