Baris has another fillet question. :)
All  1-4  5-10
8457.5
Hello Baris,
What is the ideal fillet size you were looking for?
8457.6 In reply to 8457.5
Hi OSTexo. I wanted to have a smoother transition from the center X shape to the sphere body of the drone. Any value beyond 0.145 causes fillets to overlap. The desired look is similar to this:
I'm still happy with what I could achieve with MoI. Learned a ton and I'm doing stuff which I haven't been able to do so easily in Cinema 4D. :) This is how my work looks with some quick texturing:
8457.7 In reply to 8457.6
8457.8 In reply to 8457.7
Mind = Blown. I have to experiment with that tonight. Thank you PaQ!
PaQ President! ;)
8457.10 In reply to 8457.6
Here's also a quick look at how you can blend disparate shapes...
The end result STILL has some stresses in the surface, but I chose a pretty large gap. You could use smaller gaps to get better blends. I also used extreme values. where we went from .145 to 1!
Also, the starting shape, doesn't lend itself to "beautifully melted transforms". that shape could be adjust to get a more organic look, if that's what someone wanted.
Anyway, This was just an add.... your model looks good AS IS!
EDITED: 10 Jun 2017 by BURRMAN
Show messages: All  1-4  5-10
