Node editor UI
All  1-2  3-12
8456.3 In reply to 8456.2
thank's for the help I have modified the editor.css file and got a good result.
The only thing is the info panel now opens on the left side of the screen and
not the right as normal. I did increase the panel width from 240 to 320.
There is a editor-hd.css file, does this need modifying also ?
Barry
8456.4 In reply to 8456.3
Hi Barry, can you please post a .zip file of your modified node editor? If you can post the entire thing so I could take a look at it over here maybe I'll be able to figure out why it's moved to the left side for you.
8456.5 In reply to 8456.4
here is my modified file.
Barry
8456.6 In reply to 8456.5
Hi Barry can you please post your entire node editor folder zipped up so I can make sure I've got all the same stuff as you.
8456.7 In reply to 8456.6
file attached.
Barry
EDITED: 10 Mar 2023 by BARRY-H
8456.8 In reply to 8456.7
Hi Barry, it's because of using // for commenting out stuff in the editor.css file. Unfortunately unlike .js files, css doesn't understand // meaning a comment, it only knows /* */ for comments.
So in the .node-panel class in editor.css, when you have this:
	width: 300px;//240
	right: 0px;
it's going to think you have 2 properties there named 'width' with a value of 300px and then another one named '//240 right' which won't be recognized so essentially right: is disabled there.
If you remove the // comments or switch them to /* */ then shut down and restart MoI you should then be back to what you want.
You may have had a few other various side effects from the // comments effectively disabling the property on the next line after in other areas too.
8456.9 In reply to 8456.8
I have removed all the comment tags but still the same.
I will try installing a fresh copy of the node editor and retry editing without comment tags.
Barry
8456.10 In reply to 8456.9
Hi Barry, hmm removing the // comments worked for me over here but I did have to exit MoI and restart it, did you do that part?
Anyway if you start fresh and don't put in any // comments that should work too.
8456.11 In reply to 8456.10
Michael,
sorted it there was an old core file from a previous version of node editor still in the ui directory.
Removing that as cured the issue. Bad house keeping by me sorry about that.
I have a much more useable node editor ui now.
So again many thanks
Barry.
8456.12 In reply to 8456.11
That's great Barry, you're welcome!
Show messages: All  1-2  3-12
