ElectricImage Fact support?
All  1-8  9-12
845.9 In reply to 845.8
Hey Michael,
Okay, I spent the morning doing some tests based on what you wrote above.
I have successfully imported the model into EI with no surfacing artifacts!
Nice!
You were correct in suggesting that EI was lookign for quads and traingles only.
But I had to run it through "transporter", which converts files to .fact files. I had been doing
that the whole time but, I had to deactivate all the shading and angle settings to off
in order to get a successful import.... don't know why that worked but it did.
The N-gons did not work with any combination of settings I tried.
So I certainly can start using MOI with my EI projects, but still think
direct "fact" support would be great, and would attract many EI users
to the software.
Thanks for the help Michael,
Mike Fitz
www.3dartz.com
845.10 In reply to 845.9
I'm going to try and get some time to set up a fancy render of
this model I just whipped up for my EI tests.
I'm really happy with the fillets tool ability to handle tight corners now!
Nice
Mike Fitz
www.3dartz.com
845.11 In reply to 845.9
Hi Mike, that's great!
So let me verify for future reference in case others ask me this question -
you need to switch to Quads & Triangles output, and then did you also need to turn off welding when exporting from MoI ?
Then when using the EI converter, turn off shading and angle settings so that it will use the shading information stored in the OBJ file instead of creating its own shading from averaging the polygon data.
Is that correct?
Basically once you have set OBJ output to Quads & Triangles and turn welding off, that puts the exact same information into the OBJ file as what I would write into a FACT file.
Then the question I would have is why does EI make you jump through some extra hoops with a separate converter and with turning off settings for shading, instead of using the good shading from the file by default?
If they would have built-in support for reading OBJ, and also default to using the good shading information ("vertex normals") that are stored in the OBJ file, that would streamline this process and make EI read OBJ files just as easily as it reads FACT files... At least that's what it sounds like to me.
Is there any chance they might tune up these procedures on their end to make EI more friendly to OBJ format? OBJ format is now pretty much the most common format used for data exchange, so it makes things a lot easier for everyone when a program has good support for a commonly used file format like this. It's just a lot easier for me to focus my attention on a smaller number of more commonly used file formats than to try and develop a whole bunch of different specialized formats. File format work just tends to be really pretty finicky and requires quite a lot of testing from my end to make sure that it is working correctly, so each one that I try and tackle is a pretty big investment of time...
845.12 In reply to 845.11
Hey Michael,
yes you are correct.
the only specific is that I got great results with
either triangles only or quads and triangles.
With Welding on, the imported obj to the converter "transporter" comes in spikey.
With Welding off, the imported obj to Transporter comes in clean and smooth and
is saved to fact format which comes into EI clean and smooth.
All surfacing settings were deactivited in Transporter, then save as fact.
Mike
Here is a screen cap from EI.
Show messages: All  1-8  9-12
