Random / Distort Curve
 1-5  6-25  26
8440.6 In reply to 8440.5
As OBJ don't export surface alone i take a thickness with Extrude so can can export in OBJ!
Now import format Obj inside SImlab take 2 seconds! :)
Of course i can take a very little thickness for simulate a "surface alone" ! ;)
And better I can explode inside Simlab so I have my surface alone! :)
So perfect! Trick is OBJ volume and not a surface STEP export from Moi!
Do you want a piece of chocolate ? ;)
EDITED: 25 May 2017 by PILOU
8440.8 In reply to 8440.6
Hi Pilou, you can export a single surface to OBJ format.
Damned! You right! I don't know why I don't see that!
Maybe because that was too speed and don't press the button OK but the "red x" when the OBJ image return on the Moi's Screen!
So more & more easy!
Learning the step STEP Stp export in Moi and the Explosion in SimLab! :)
Hoppefuly i have not too many sites to modify for explain my error! :)
A bug inside Distort Curves!
But not very redoable!
Blocks Moi3D!
I made a Sphere : some Curve iSo UV above - Kill the Sphere - Erase Top / Bottom calotte by triming Vertical curves by calottes
(see last image follow :)
Not bug when I Separe curves resulting!
8440.11 In reply to 8440.10
Hi Pilou, can you post the 3DM model file with the curves in it that won't distort?
I am abble to remake the bug!
8440.13 In reply to 8440.11
Big luck!
New session! French Enable
Exactly the description that i made previous! Sphere etc...
No Separate
Of course i save the file before launch the Distort Curves!
Moi blocked : only Alt + Ctrl + Del save the thing!
Have happy debug!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bug_distort.3dm
8440.14 In reply to 8440.13
Hi Pilou, I can't seem to repeat the distort script error over here using your file. Here's what I tried: open bug_distort.3dm, select curves, run _DistortCurves and manipulate the slider for a while. Are you using some particular parameters? Which version of _DistortCurves are you using, it is the last one with rebuild included or an earlier version?
8440.15 In reply to 8440.14
For that file i have made absolutly nothing special out that I have described!
It was a new launch of Moi.
It's // DistortCurves v.0.9 - Max Smirnov. 2014
there is Rebuild inside
Will stay a mystery like the Voronoi in the past! ;)
PS I reload the file above: no problem! (before reload the new version 1)
PSS I see that is not the V 1 of the DisturbCurves : maybe that is that...
EDITED: 26 May 2017 by PILOU
8440.16 In reply to 8440.15
Hi Pilou, I think that you might have had a degenerate curve meaning a curve with all its control points squished together when you got that script error. That's the main way I'd think the script would fail in the particular spot you showed. But your attached file above doesn't seem to have the bad curve in it anymore.
8440.17 In reply to 8440.16
Seems it's not redoable at each time!
First time i try the V1 Crash!
Crash arrives before any moves of cursors of distort curves!
Seems it's the double Trim in one time who makes the bug!
If i make it in 2 times there is no crash!
Here in one time = crash! (but not redoable at each time)
so mysterious instability for me :)
PS I call the distort curve by the general list of bottom line icons...(Ext.scripts)
8440.18
Hey Pilou, I´m sorry to open this thread again, but I got a little question: I´ve read your post, but I could not open the link to the "random curve" script. Is this the same like "randomize curve"?
It´s just pure interest :)
8440.19 In reply to 8440.18
You have a command RandomCurves here!
https://moi3d.com/wiki/MaxScriptArchive
And no it's not the same than Randomize!
Sorry in French https://moiscript.weebly.com/uploads/3/9/3/8/3938813/randomize_fr.zip
First is a generator!
Second is a transformer of something existant!
And you have a third one : Distort
Distort is in the MaxScriptArchive above
EDITED: 17 Jan 2023 by PILOU
8440.20 In reply to 8440.19
Randomize English version here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5
8440.21
Alright! thanks so much! I didn´t know the "random curves" script.
Is there anywhere a complete database of all scripts and commands? I know the links to the libaries, but everytime when I browse through the forum, I find some new (actually old) links in an old discussion..
Thanks for your last answers!!
Koi
8440.22 In reply to 8440.21
Hi Koi,
Look for "Burr's script archive" at http://moi3d.com/resources .
8440.23 In reply to 8440.22
hi Michael,
I did, but I found a few which were not listed, I tihkn it´s still fine, I will just keep hanging around the forum and your posts and I think I will find all I need :)
I love this forum, thank you so much!
Koi
8440.24 In reply to 8440.22
I just updated that forum post and uploaded the latest version of the commands and scripts folders.
scripts from 169 to 203
commands from 202 to 250
Still never really cleaned it up of iteration duplicates, etc. Missed some while I was slacking off.
Also, It is not "Complete" in that Sometimes I don't grab something if it seems too "Trivial". Like "Shortcuts" or too "Personalized". No real custom "UI" stuff. No Node stuff. So you can definitely find other goodies if digging.
it is everything I have as of today. I think the thread labels the last edit date to track that.
8440.25 In reply to 8440.24
Thanks for gathering that stuff up Burr!
Show messages:  1-5  6-25  26
