change order of menus
All  1-4  5-11
844.5 In reply to 844.4
I was able to separate the construct and transform tabs. But the select tab gave some problems because I either ran out of vertical screen space or something else. In any case it doesn't roll-down even if some other tabs are rolled-up. It's not really a problem, though.
844.6 In reply to 844.5
Hi Anthony, a fixed up version with a working select is attached here.
It wasn't working because the old Select body stuff was still up in the old spot, making 2 elements with the same "SelectTabContent" id.
A couple of things in that mechanism are linked by id names, duplicate ids kind of messes it up.
I'm glad you were able to morph the UI more to your liking!
844.7 In reply to 844.6
Michael, just a quick note the side pane rearrangement is sweet :) Thanks
844.8 In reply to 844.7
Here you go, try this version (make sure to back up your old version first).
Everything works, the question is how long can you stand to use it? ;)
844.9 In reply to 844.8
LOL :)
844.10 In reply to 844.6
Thanks for the fixup, Michael. I "zigged when I should have zagged," or in my case "copied when I should have cut." Now I have the interface just as I wanted.
PS: now I hate the marquee tag even more than before. And I didn't think that was possible. :)
844.11 In reply to 844.10
If there was only a <marqueeblink>.... That would be the coolest EVER!!! ;)
Show messages: All  1-4  5-11
