How to rotate and Move along path line ?
 1-20  21-24
8411.21 In reply to 8411.20
ça c'est sûr! :)
Quelle est la courbe de départ?
J'ai du mal à comprendre si l'on veut un volume en quoi un Tubage à un ou deux Rails ne répond pas à la question ?
Même à un rail...
Si c'est pour un toboggan Pipes 2 devrait faire l'affaire ?
EDITED: 9 May 2017 by PILOU
8411.22 In reply to 8411.15
Hi nordzway, sorry right now there isn't any way to set Twist = Flat in the Flow tool. I do want to add something for controlling banking with curve-to-curve flow in the future.
If you need Twist = Flat then I'd recommend using Sweep instead of the Flow method.
8411.23 In reply to 8411.22
ok thank you for your time
I am excited to see this addition of flow
8411.24 In reply to 8411.23
Hi nordzway, also another way that might work with Flow right now would be to sweep a line with Twist = flat to make a ribbon surface like in some of Pilou's images above and then use surface-to-surface Flow instead of curve-to-curve Flow.
Show messages:  1-20  21-24
