Simple Circle
All  1-4  5-7
8409.5 In reply to 8409.4
Hi VaRMiT, it would probably help if you had an example image or sketch of what you're trying to do. Do you mean something like a sphere?
You can use Revolve with the axis touching the circle if you want to get rid of the hole.
Or if you want a flat area in the middle, revolve an arc instead of a circle like this:
8409.6 In reply to 8409.4
quote:
Circle or even a square, I want it to be solid with out the hole.
If you, by any chance, mean something like a disk, then you just could use the planar command.
But the disc with Planar command is not a "solid" : it's just a Surface!
So make an Extrude for add thickness ad obtain a "Solid" volume! :)
But in this case you can use directly the native Cylinder function! :)
Show messages: All  1-4  5-7
