How to have regular slope in my spline
8405.1
I try to have a regular slope in my spline course , i think i need a " smooth curve tool " or Something
i try to recreate the course of an water slide
my result is poor, because i connect hélix with another arc curve... is not the best i think :
thank you
EDITED: 3 May 2017 by NORDZWAY
Size: 587.9 KB, Downloaded: 30 times, Dimensions: 1057x695px
The slope maybe the native Helix + Blend functions ?
then Plugin Pipe2
http://moi3d.com/forum/index.php?webtag=MOI&msg=1463.48
EDITED: 3 May 2017 by PILOU
8405.3 In reply to 8405.2
thank you, i just try the pipe2, the tool work great but its no help
blend tool help a little
Thank you for your time.
8405.4 In reply to 8405.1
Hi nordzway, the usual way would be to adjust control points of your curves if you don't like their shape.
Can you please post your 3DM model file so I can take a look at your object structure?
8405.5
Hello,
Would you mind sharing the curve set?
8405.6 In reply to 8405.5
My problem is solved ;)
thank you.
