Export as STEP - repeating Object Names
All  1  2-3
8399.2 In reply to 8399.1
Hi Alex, sorry no currently there isn't any way of stopping that from happening with STEP export and re-import. The repeating name is something in the STEP library that kicks in when instancing is not being used directly I think. I should be able to investigate it in v4 when I'm working on instancing.
Instead of using STEP format for a direct round trip, it's better to use 3DM format. That's the main file format intended to be used for projects you just want to save and load back into MoI instead of sending to other apps.
8399.3
Thanks for speedy reply figured something along those lines - I currently keep the 3dm file as master but as STP is the transition file to manufacture I some times have the stp file/part isolated and I tidy up the imported name.
But good to know its in the stream for V4.
all the best
Alex.
Show messages: All  1  2-3
