Mini tut :)
 1-6  7-26  27-46  47-53
8388.47 In reply to 8388.46
Hi Metin, also you can use Construct > Curve > isect to generate a curve result directly.
8388.48 In reply to 8388.47
Nice, thanks Michael!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
8388.49
Just learned this tip from Michael:
Use Options ➔ Rotate/Pan/Zoom options ➔ Link ortho views to synchronize zooming and panning of all orthographic views.
─ Metin
About the Surface above...with the interactive moving points...
Seems no need to make "Histo" after the Loft ?...
EDITED: 10 Jun 2021 by PILOU
8388.51 In reply to 8388.50
Ah yes, you can also simply manipulate the resulting surface points.
─ Metin
For have longitudinal sections to the extremities with LineWeb
Make curves longer and trim at the end!
Here One curve (longer over the origin), Array Circular (nb3, 90° ), LineWeb Twice, Trim
EDITED: 28 Jun 2021 by PILOU
by Moi3d Not Pomoi
Show messages:  1-6  7-26  27-46  47-53
