Mini tut :)
1-4
5-24
25-44
45-53
Metin (METIN_SEVEN)
9 Jun 2021 (45 of 53)
8388.45
In reply to
8388.44
Thanks for the GIF, Pilou! That shows it much better.
─ Metin
visualizer • illustrator • 3D designer —
metinseven.nl
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Metin (METIN_SEVEN)
9 Jun 2021 (46 of 53)
8388.46
A very fast way to create a curved surface is to Boolean Intersect a closed curve with an open curve.
Optionally, the resulting surface boundary can be turned into a curve again.
Select the resulting surface and activate History to manipulate the operands and watch the result update.
─ Metin
metinseven.nl
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
9 Jun 2021 (47 of 53)
8388.47
In reply to
8388.46
Hi Metin, also you can use Construct > Curve > isect to generate a curve result directly.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Metin (METIN_SEVEN)
9 Jun 2021 (48 of 53)
8388.48
In reply to
8388.47
Nice, thanks Michael!
─ Metin
metinseven.nl
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Metin (METIN_SEVEN)
9 Jun 2021 (49 of 53)
8388.49
Just learned this tip from Michael:
Use Options ➔ Rotate/Pan/Zoom options ➔ Link ortho views to synchronize zooming and panning of all orthographic views.
─ Metin
metinseven.nl
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
9 Jun 2021 (50 of 53)
8388.50
About the Surface above...with the interactive moving points...
Seems no need to make "Histo" after the Loft ?...
EDITED: 10 Jun 2021 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Metin (METIN_SEVEN)
10 Jun 2021 (51 of 53)
8388.51
In reply to
8388.50
Ah yes, you can also simply manipulate the resulting surface points.
─ Metin
metinseven.nl
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
28 Jun 2021 (52 of 53)
8388.52
For have longitudinal sections to the extremities with LineWeb
Make curves longer and trim at the end!
Here One curve (longer over the origin), Array Circular (nb3, 90° ), LineWeb Twice, Trim
EDITED: 28 Jun 2021 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
14 Apr 2023 (53 of 53)
8388.53
by Moi3d Not Pomoi
My Moi French Site
My MagicaVoxel Gallery
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
5-24
25-44
45-53
