Mini tut :)
 1-2  3-22  23-42  43-53
8388.43
When points are activated and a curve is not selected, you can click and drag on the curve to move the corresponding curve area (region-moving neighboring points).
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
8388.44 In reply to 8388.43
So transformation in real time!
8388.45 In reply to 8388.44
Thanks for the GIF, Pilou! That shows it much better.
─ Metin
8388.46
A very fast way to create a curved surface is to Boolean Intersect a closed curve with an open curve.
Optionally, the resulting surface boundary can be turned into a curve again.
Select the resulting surface and activate History to manipulate the operands and watch the result update.
─ Metin
8388.47 In reply to 8388.46
Hi Metin, also you can use Construct > Curve > isect to generate a curve result directly.
8388.48 In reply to 8388.47
Nice, thanks Michael!
─ Metin
8388.49
Just learned this tip from Michael:
Use Options ➔ Rotate/Pan/Zoom options ➔ Link ortho views to synchronize zooming and panning of all orthographic views.
─ Metin
About the Surface above...with the interactive moving points...
Seems no need to make "Histo" after the Loft ?...
EDITED: 10 Jun 2021 by PILOU
8388.51 In reply to 8388.50
Ah yes, you can also simply manipulate the resulting surface points.
─ Metin
For have longitudinal sections to the extremities with LineWeb
Make curves longer and trim at the end!
Here One curve (longer over the origin), Array Circular (nb3, 90° ), LineWeb Twice, Trim
EDITED: 28 Jun 2021 by PILOU
by Moi3d Not Pomoi
Show messages:  1-2  3-22  23-42  43-53
