Mini tut :)
 1-8  9-28  29-48  49-53
Loft power! ;)
Rail Revolve
Iso curves
Kill or Hide Rail Revolve + Surface
Loft and deform real time curves as you want (general, by points ...etc)
Here just horizontally :)
Have fun!
EDITED: 23 Nov 2020 by PILOU
Close a curve not trimed with a "wall" (so automatic Trim)
Blend Cap by Michael
http://moi3d.com/forum/index.php?webtag=MOI&msg=7370.6
A we can't make "Show points" neither the "Edit Frame" or partial "Resize" for deform partial parts
The trick is to make 2 "Flow" command!
(or more if you have a tortured object) that works perfectly! :)
One view Top
One view Side
Here the view Top (but one extremity is always deformed)
Here the second! (view side)
Et voilà! Happy new year!
EDITED: 2 Jan 2021 by PILOU
the trick of the curves seams (no corners points) Join all curves . SAT Export /Import et voilà!
8388.33 In reply to 8388.32
Hi
you can use Seamless script in MoI :)
Size: 367.8 KB, Downloaded: 381 times, Dimensions: 1136x832px
8388.34 In reply to 8388.33
Where is the original of seamless script?
i have this one Delcorners by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.4
8388.35 In reply to 8388.34
here the command
8388.36 In reply to 8388.35
Thx what is the author ?
8388.37 In reply to 8388.36
dunno ?
8388.38 In reply to 8388.37
with the name _seamless.js seems Max SMirnov ?
Else seems don't works for me! :( (or i miss something)
works with the export / Import Sat (don't shown here)
Edit : that 's works! I have forgotten to Join the curves before lauch the script !!!!
EDITED: 7 Mar 2021 by PILOU
Contra indications to using "seamless"?
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.11
so :)
EDITED: 23 May 2021 by PILOU
If someone can tell me why i have this result for my Sweep ? An only one "solid" arch !
(very happy of the infinite possibilities of this Sweep) but some perplex about the result! :)
I can of course also modify the resulting solid ! :)
EDIT
I have my answer ;)
<< It’s something like the centroid of each curve then it’s expecting them to be arranged in a line along the cplane’s x or y axis directions. So it’s sorted by that distance and ones that are tied will be random which one is taken over another.
Michael
8388.43
When points are activated and a curve is not selected, you can click and drag on the curve to move the corresponding curve area (region-moving neighboring points).
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
8388.44 In reply to 8388.43
So transformation in real time!
8388.45 In reply to 8388.44
Thanks for the GIF, Pilou! That shows it much better.
─ Metin
8388.46
A very fast way to create a curved surface is to Boolean Intersect a closed curve with an open curve.
Optionally, the resulting surface boundary can be turned into a curve again.
Select the resulting surface and activate History to manipulate the operands and watch the result update.
─ Metin
8388.47 In reply to 8388.46
Hi Metin, also you can use Construct > Curve > isect to generate a curve result directly.
8388.48 In reply to 8388.47
Nice, thanks Michael!
─ Metin
Show messages:  1-8  9-28  29-48  49-53
