Mini tut :)
 1-7  8-27  28-47  48-53
A little trick but very frequent!
Always verify if there are no Curves overlaped on Edges!
Else Blend will failed!
Just use the Browser for "hide" them before the Blend!
Loft power! ;)
Rail Revolve
Iso curves
Kill or Hide Rail Revolve + Surface
Loft and deform real time curves as you want (general, by points ...etc)
Here just horizontally :)
Have fun!
EDITED: 23 Nov 2020 by PILOU
Close a curve not trimed with a "wall" (so automatic Trim)
Blend Cap by Michael
http://moi3d.com/forum/index.php?webtag=MOI&msg=7370.6
A we can't make "Show points" neither the "Edit Frame" or partial "Resize" for deform partial parts
The trick is to make 2 "Flow" command!
(or more if you have a tortured object) that works perfectly! :)
One view Top
One view Side
Here the view Top (but one extremity is always deformed)
Here the second! (view side)
Et voilà! Happy new year!
EDITED: 2 Jan 2021 by PILOU
the trick of the curves seams (no corners points) Join all curves . SAT Export /Import et voilà!
8388.33 In reply to 8388.32
Hi
you can use Seamless script in MoI :)
Size: 367.8 KB, Downloaded: 381 times, Dimensions: 1136x832px
8388.34 In reply to 8388.33
Where is the original of seamless script?
i have this one Delcorners by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.4
8388.35 In reply to 8388.34
here the command
8388.36 In reply to 8388.35
Thx what is the author ?
8388.37 In reply to 8388.36
dunno ?
8388.38 In reply to 8388.37
with the name _seamless.js seems Max SMirnov ?
Else seems don't works for me! :( (or i miss something)
works with the export / Import Sat (don't shown here)
Edit : that 's works! I have forgotten to Join the curves before lauch the script !!!!
EDITED: 7 Mar 2021 by PILOU
Contra indications to using "seamless"?
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.11
so :)
EDITED: 23 May 2021 by PILOU
If someone can tell me why i have this result for my Sweep ? An only one "solid" arch !
(very happy of the infinite possibilities of this Sweep) but some perplex about the result! :)
I can of course also modify the resulting solid ! :)
EDIT
I have my answer ;)
<< It’s something like the centroid of each curve then it’s expecting them to be arranged in a line along the cplane’s x or y axis directions. So it’s sorted by that distance and ones that are tied will be random which one is taken over another.
Michael
8388.43
When points are activated and a curve is not selected, you can click and drag on the curve to move the corresponding curve area (region-moving neighboring points).
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
8388.44 In reply to 8388.43
So transformation in real time!
8388.45 In reply to 8388.44
Thanks for the GIF, Pilou! That shows it much better.
─ Metin
8388.46
A very fast way to create a curved surface is to Boolean Intersect a closed curve with an open curve.
Optionally, the resulting surface boundary can be turned into a curve again.
Select the resulting surface and activate History to manipulate the operands and watch the result update.
─ Metin
8388.47 In reply to 8388.46
Hi Metin, also you can use Construct > Curve > isect to generate a curve result directly.
Show messages:  1-7  8-27  28-47  48-53
