Mini tut :)
 1  2-21  22-41  42-53
The Blend Function as research of form :)
Draw Curves and Extrude them (or any other transformations for make surfaces )
Select all curves : kill them
You can now use the Blend function :)
Select Edges...Blend them et voilĂ  ...
Any generic transformations (Move, Rotate, Scale of these surface(e) alone or not will be persistant...)
(along you make only generic transformations)
You can of course Show Points of these surfaces and transform these points!
Add Points to these Surfaces breaks the process so Add Points to the surface(s) BEFORE the Blend !!!
EDITED: 23 Jun 2020 by PILOU
8388.24
merge a sphere with cylinder to obtain curve for fillet
- Tudor -
8388.25 In reply to 8388.24
Nice! Very useful.
Thanks for sharing.
Mik
8388.26 In reply to 8388.24
Tricky even the orange surface is not more in the straight extention of the tube...
For "blobby" forms
- Extrude Base
- 2 curves projected
- Trim
- Scale Bottom piece trickily (aligned on the Bottom face)
- Naked
- Blend (you can regulate the Bulge - Maybe use the Planar section for the bottom vertical face)
(if you want make Fillets better to kill bottom vertical face and make it "Planar" )
Blend with planar section option
Blend elaborated so you can put heavy bulge! :)
Arc without headache! :)
The trick of the Scale
PS you can even go more speedy in drawing only one curve projected! ;) Result will be the same!
(if you want same form Top / Bottom)
So ultra speed! :)
EDITED: 26 Jun 2020 by PILOU
A little trick but very frequent!
Always verify if there are no Curves overlaped on Edges!
Else Blend will failed!
Just use the Browser for "hide" them before the Blend!
Loft power! ;)
Rail Revolve
Iso curves
Kill or Hide Rail Revolve + Surface
Loft and deform real time curves as you want (general, by points ...etc)
Here just horizontally :)
Have fun!
EDITED: 23 Nov 2020 by PILOU
Close a curve not trimed with a "wall" (so automatic Trim)
Blend Cap by Michael
http://moi3d.com/forum/index.php?webtag=MOI&msg=7370.6
A we can't make "Show points" neither the "Edit Frame" or partial "Resize" for deform partial parts
The trick is to make 2 "Flow" command!
(or more if you have a tortured object) that works perfectly! :)
One view Top
One view Side
Here the view Top (but one extremity is always deformed)
Here the second! (view side)
Et voilĂ ! Happy new year!
EDITED: 2 Jan 2021 by PILOU
the trick of the curves seams (no corners points) Join all curves . SAT Export /Import et voilĂ !
8388.33 In reply to 8388.32
Hi
you can use Seamless script in MoI :)
Size: 367.8 KB, Downloaded: 381 times, Dimensions: 1136x832px
8388.34 In reply to 8388.33
Where is the original of seamless script?
i have this one Delcorners by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.4
8388.35 In reply to 8388.34
here the command
8388.36 In reply to 8388.35
Thx what is the author ?
8388.37 In reply to 8388.36
dunno ?
8388.38 In reply to 8388.37
with the name _seamless.js seems Max SMirnov ?
Else seems don't works for me! :( (or i miss something)
works with the export / Import Sat (don't shown here)
Edit : that 's works! I have forgotten to Join the curves before lauch the script !!!!
EDITED: 7 Mar 2021 by PILOU
Contra indications to using "seamless"?
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.11
so :)
EDITED: 23 May 2021 by PILOU
Show messages:  1  2-21  22-41  42-53
